Question about Refrigerators
Refrigerator is on but is not getting cold and error code is coming up on panal. The major part is i cant find manuel so i dont know what the model number.Please help i dont want to call a repaitman just yet or worse have to buy a new refrigerator. Thank you.
  • 4,793 Answers
Manually defrost unit(no hot water) wash out interior with bicarb, dry out.then using a thin wire with a very small piece of cloth dipped in clorine bleach clean out drain/vent from inside to outside.swith unit back on. all is well when operating temp reached.no need to call repairman for this.(this is the first thing they do......anyway)
Posted on Feb 09, 2010
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Refrigerator will not get cold?
I would disconnect the power to the refrigerator and then take the connections loose on the compressor and use an ohmeter to see if there is continuity between all of the posts on the compressor. If there is then it is probably a problem in the control section. Let me know.
Mar 08, 2012 | Refrigerators
BMW k1200GT 06 Model
yep,,,its under the seat,, but it dont come out that way,,,take off the right side panal take out the engine ECU and then you can get the battery out,,,they dont make it easy do they?
Mar 13, 2010 | 2006 BMW K 1200 GT
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Mar 08, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
REFRIG WILL NOT GET ANYTHING COLD
make sure there is no frost buildup behinde the freezer back panal and the ducts to the frig are clear. Leaving the door open will make a lot of frost and diminish the cooling capacity.
Eric
Jun 24, 2009 | Amana ARB190ZCS Bottom Freezer...
Maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Oct 02, 2008 | Refrigerators
Refrigerator
need model number cant help if we dont know what meodel it ios but if everything freezes repl the thermostat in refrigerator side
Aug 16, 2008 | Frigidaire FRS266ZDSB Side by Side...
Fridge stopped getting cold
Check for frost on the back wall of the freezer section. If there is frost there your problem is defrost related to a timer or defrost heaters. I say this because you indicated it still makes ice cubes which indicates it is still working to some degree. Check the condenser for cleanliness and clean if necessary. Under the refrigerator front behind toe plate and /or in back behind removable panel.
May 19, 2008 | GE Refrigerators
Reset security code
i bought a audiobahna3551 cd player at the pawn shop and i need the code for it
Jul 30, 2007 | AudioBahn A3351 CD Player
Camcorder
error message look in manuel for codes
Mar 03, 2018 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
