Question about Lexmark Wheelwriter 15 Series II Typewriter
When I type it is only printing 1/2 of the letters and or numbers it is cutting off the bottom half
  • Lexmark Master
  • 3,594 Answers
The platen (black roller) probably isn't fully seated, press down firmly on both ends of the platen. If it comes up again the latches are broken and you'll need a platen.
DickyO
Posted on Feb 09, 2010
  • Asian-gem
    Asian-gem Apr 12, 2012
    Yes It worked! I took my platen (black roller) and took up both ends off (but one at a time) and gently lifted up (not too high) to re-seat the platen back onto their holders (which in my Wheelwriter 15 was two clips on top also which pushed down to re-seat the platen's ends back so that it was seated correctly. It was not broken but probably because I have moved it several times -- it probably shifted out of its position. Once it was re-seated, it now types the complete letter both top and bottom halfs -- thank you so much for saving me money to take it to the repair shop which would probably charged me an arm and a leg! So simple, yet who would ever have known :)
I am giving the margine in Adobe Pagemaker in legal size paper left 2", Right 1", top2" & bottom 2" but printer is print on paper from top only half inch margin
Did you remember to change the paper type in the printer settings to legal, before printing? If not it will use the default, usually letter size.
Feb 27, 2015 | HP LaserJet M1005 MFP Printer
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
Wheelwriter 35 cutting off bottom of letters
First thin to do is to be sure the platen (rubber roll) is fully seated in the T/W side frames. press firmly on both ends of the platen.
DickyO
Mar 02, 2010 | Lexmark Wheelwriter 35 Series II...
Bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
Jul 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
On some lines the letters are cut in half and not lined up
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X5150 All-In-One InkJet Printer
Cant print page numbers or footer, they are cut in half
depending on your physical location you may need to change the default paper type for your printer..
American default is Letter, where as Australia is A4, these paper sizes are only slightly different.
I'd be checking your margins also in your document.... Are the numbers cut off when you do a print preview?
Jan 07, 2009 | Office Equipment & Supplies
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
