Question about Photography
Sears ks500 match meter not moving
Hello.
Anyone know how to fix the meter in a Sears KS500? I have place fresh bateries in the camera but the needle does not respond to sunlight or changes in ligh. I have tested the battery in another camera and confirmed that it is good.
Thanks
  • Old FRT Nov 10, 2008
    Have the Sears KS-500 in almost mint condition, everthing works perfectly except for the match needle. First thing I did was clean the battery contacts on both camera and door and add new batteries. Nothing! It's in my collection so would not bother to send it to a repairman.
    Retired Professional Photographer. Any other ideas?
    Old FRT
  • 667 Answers
Try cleaning the contact inside the camera and the battery cap with a hard eraser. You need good contact for power from the batteries. The inside of the cap is usually the problem.
Posted on Feb 22, 2008
The light meter is not working on my Pentax K1000
there are three different possibilities. remove three screws, take off bottom cover. remove three screws of battery holder, lift to see if the battery wire has corroded or broken off. solve by extending wire and resoldering. the next involves removing the top cover to see if the meter coil is dead,if this is the case it needs to be replaced, or there is a broken lead somewhere. usually it is cause no. 1.
Dec 09, 2013 | Pentax K1000 35mm SLR Camera
I recently bought a nikon f2. After I bought a battery (single 3 volt as recommended by the person at batteries plus) I opened the battery compartment, with the positive pole pointing out, closed the...
The Nikon F2 for me is the best mechanical film camera ever produced. The only electrical or battery- dependent part is its metering. Meaning to say, even without batteries, the F2 should work and take pictures on all shutter speeds. Most probably, the F2 that you bought has a non-working photomic meter finder due to a defective ring resistor, a part that is usually the first thing that would fail on this camera. What, then, are your options? One, have the meter fixed by a competent manual camera technician. Two, buy a working Photomic finder and replace what you have. Three, buy or use a handheld meter. Four (the least expensive), use the sunny 16 rule. As added reference, here's a link that might help enlighten you more about how the F2 metering works: http://www.mir.com.my/rb/photography/hardwares/classics/nikonf2/prisms/dp11/index.htm
Mar 07, 2011 | Nikon Photography
I need code to unlock my GU 295 lg
Contact your cellular service provider and request Tech Support assistance. They will provide you with a Master Unlock Code for your phone. After entering it, you can then change the PIN to one you'll remember.
If you need the code to unlock your phone to use with another service provider, your best bet is eBay. Most unlock codes can be purchased for under $1.00.
We cannot provide Security codes on FixYa if you've forgotten your PIN as we have no way to verify the ownership of your phone. Calling your service provider and requesting tech support assistance is the best way and its free.
If all else fails, visit this website: http://www.onlinegsmunlock.com/unlock-your-phone/rs7wp2/
Or, you can Google "Secret Codes LG GU295" and review the information from available web sites.
Jan 26, 2011 | LG KS500 Cell Phone
When talking on the phone, the phone keeps beeping. What am I doing wrong.
Please time the beeps.Most likely the phone beeps after every minute.If I am right that means that there's nothing wrong with your phone. The beep is like a time keeper.Sort of like trying to remind you that the 1st minute is up, then the second and so on...
Hope it helps.
Feb 07, 2010 | LG KS500 UNLOCKED GSM Quad band Cell Phone
Calibration of the sphygmomanometer
Unscrew the silver ring from around the dial face. Lift off the clear cover. Gently pull the needle off the pin. Re-align needle. Gently push the needle back on to the pin taking care not to push to hard or bend the needle. I hope this corrects your problem.
Jan 27, 2009 | Moore Medical Blood Pressure Kit W/...
Autotuner problem with Kenwood TS=450SAT
Sorry, I did not realize that this was a fix-it-for-hire place. I thought it was a place for free advice
I will take my problem elsewhere.
73'
WB9RWW
Jan 03, 2009 | Radio Communications
Is my tach broken?
I have the same problem on my '05 monster 620. I hear it's very common. Upon calling my trustworthy mechanic (not the dealer), he informs me this is quite common. The glue holding the needles in place is apparently not the greatest, and moisture inside the instrument panel screws it all up. He recommended I take an engine speed meter, take apart the instrument panel, and glue the needle back in place at the appropriate reading for the engine speed. I haven't tried to do this yet as the rainy season just started, and I don't have a garage :/ Let me know if you have any success in this regard as I'm very interested in hearing about it.
Nov 20, 2008 | 2003 Ducati Monster 1000s i.e.
Meter on ae1 not working when aperture setting adjusted
On that camera the needle is not supposed to move when the f-stop ring is turned. It should stay on whatever number it is on and you should set the ring manually to whatever the needle points to.
That camera was really not made to be easy to use in the manual mode. I guess Canon thought everyone would just use it in Auto.
CameraRepairs
May 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon FTB meter
The battery only powers the meter needle. The aperture match needle is controlled by the lever that is to the right of the mirror box. You can see it with the lens off while looking at the mount. It may be bent or damaged.
Feb 06, 2008 | Photography
Photography Logo
174 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
