Question about Bosch Benvenuto B30 Espresso/Coffee Maker
Hi...i have a Siemens s40 surpresso which i believe is identical to the Bosch B30 machine. ive had it for years now and about to his 9000 brews! But the problem is that the water pressure is decreasing now and im told that there could be a problem with the pressure valve?? at times it pumps, little coffey comes out of the spouint and most goes inside into the dregs / water tray, so somewhere the pressure is causing water to pump elsewhere. The pipes are not blocked... im writing as this machine does not have service centre where i live... Thanks In advance...
Lovejoyone--Neither of the sites referenced in your post ships outside the EU. I own the Bosch B30 (5 years/10,000+ brews) which is in need of some rebuilding. I can't find ANYWHERE where I can get parts for this unit. Any suggestions?
Posted on Jun 17, 2010
You have to either get a new drainage valve or buy a "DIY" set
or the big set - you can just as well change all o-rings while you are at it.
I would also change the grinding stones (or whatever it is called in english...)
Alternatively buy the stuff at http://www.juraprofi.de/ - Komtra does not provide creditcard payment option.
Have a look at their forum - it is in german - but you will find an answer to all your issues with this machine.
Posted on Apr 27, 2010
  • lovejoyone Jun 18, 2010
    Well - if you cant get the parts you can try to clean and descale the drainage valve inner parts and put silicone grease (food grade...) on the old o-rings (and other rubber rings inside the valve - not sure of the name in english....) This could solve the problem - it is worth a try. Did you ask Jura Profi if they could send to non-eu countries?
    I do not know where to buy parts apart from the sites I mentioned. But try to google.
Bosch benvenuto b30 had for years and loved. Now when use beans the coffee/espresso is too watery and pucks are like sludge after. Works good when use preground coffee .
You have accidentally turned down the brew strength selector, on front of unit just above "clean" and "descale" buttons. Dial it the the maximum. Will grind longer, make more grounds, larger puck, stronger coffee. Or this dial is broken/ wire broken etc. u can disassemble per some other posts on here and check wire connections. I did all that then realized someone had just turned it down. So I turned it to maximum strength and problem fixed.
Oct 15, 2013 | Bosch Benvenuto B30 Espresso/Coffee Maker
Problems with unit
siemens surpresso s40 can't finish calc
Mar 26, 2012 | Washing Machines
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
We have a Siemens Surpresso S40, giving 'error 8'
Error 8 indicates a technical fault. Try switching off the main switch for about 1 minute and then start it up again. If the error message persists, you will have to have the machine serviced. The most common fault would be that the machine is blocked.
Jun 06, 2011 | Coffee Makers & Espresso Machines
I turn the machine on, add the kcup and water...lights blink but nothing brews, then turns itself off...B30 unit; please advise Thanks
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 16, 2011 | Keurig B30 Mini Coffee Maker
My Keurig b30 doesn't brew and squirts hot water instead
heatman101
Nov 15, 2010 | Keurig B30 Mini Coffee Maker
Product manual
You can get the manual on the Bosch web page http://www.boschappliances.com.
The direct link for the B30 is:
http://www.boschappliances.com/kitchen-appliances-consumer-products_small-appliances_coffee-makers_benvenuto-coffee-machines_TCA6301UC.html
You can also view the parts list for the machine and order parts - click the Purchase Parts link on the B30 page.
Dec 06, 2008 | Bosch Benvenuto B20 Espresso & Coffee...
"water pipe empty" icon will not disappear from display screen 3, cannot brew coffee, first use - second machine to have this problem
I have a Siemens surpresso S40 with the same problem.
Try to fill the tank with hot water. I dont't know why but it solved the problem for me.
Jul 11, 2007 | Bosch Benvenuto B20 Espresso & Coffee...
Bosch Benvenuto B30 Espresso/Coffee Maker Logo
3,182 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Donald Currie III
Level 1 Expert
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
