Question about Crane Cow Humidifier
Cleaning I love my daughters cow humidifier but, I am unsure how to clean it and how often it should be cleaned. Can you help?
  • 2 more comments
  • cleanitfast Mar 12, 2008
    I have the cow humidifier, I empty the water each morning, but it looks like it needs a good clean. What do i clean it with and how, the opening is so small?
  • MrsHuffheinz Apr 24, 2008
    The black plastic piece in the base of my cow humidifier is flaking. How do I clean this or do I need to replace this piece?
  • Anonymous Oct 05, 2008
    I also would really like to know how to clean the internal parts.
  • mang_osteen Feb 09, 2009
    Yes, the black circular piece has been flaking. Now it no longer creates a strong enough mist. Is there a way to replace this piece, or do I need a whole new machine??
Old question but just in case someone goes to looking for an answer:
A good procedure for any ultrasonic humidifier is to switch the unit OFF and unplug it. Empty the water out. Rinse the reservoir and places where water comes in contact with hot/clean water. Do not submerge the base of the unit or anything containing electrical components! Visually inspect for dirt or mineral build up in the reservoir or where watcer comes in contact. If the water your using in the unit is soft water then de-calcifying the unit every 4 weeks is suggested. If hard water is used the unit should be decalcified every 2 weeks. You can use CLR (Calcium Lime Rust) solution or EZ Cal.
Posted on May 17, 2014
I also need some information on cleaning, specifically the base. Not sure if I should use soap or if that will affect the nebulizer?
For cleaning the reservoir, just add a capfull of bleach to some water, and swish it around intermittently for about 20 minutes -- rinse until you don't smell bleach anymore.
Posted on Apr 14, 2008
Crane humidifier stopped working
My crane cool mist stopped misting. I always use filter water. Cleaned it with vinegar. What's can I do?
Mar 02, 2013 | Crane Penguin 1 Gallon Humidifier
How to clean
You can try using either vinegar and water OR baking soda and water.
Dec 24, 2010 | Crane Cow Humidifier
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
I WAS GIVEN THE COW HUMIDIFIER AS A GIFT WHICH WAS A HAND ME DOWN AND I DONT KNOW HOW TO WORK IT.. PLEASE HELP
Hi, Looks like this should be easy to operate. These are the only directions I found for this humidifier: This Crane humidifier operates with cold tap water. Just fill the 1 gallon tank in the sink (fits most common sized sinks) and switch the unit on. The Cow Humidifier will produce cold mist instantanously. The mist output can be regulated with the control button located at the front.
Hope this helps! Hal
Jun 09, 2009 | Crane Cow Humidifier
Tank will not hold water
Hey Fly gal.. just return it.. ..??..is this a warn air humidifier??...if not, get a warm air model!!!!
Jul 17, 2017 | Crane Cow Humidifier
Sterilization
I put 1 Cup of bleach in it with warm water and let it set for about an hour. The tank is clean and you can use it over and over again. Good luck and hopefully this has helped you. I just love this machine and am glad I bought it for my son.
May 29, 2008 | Vicks Cool Mist V3500 Humidifier
Mold in vicks cool mist vaporizer
if you can take it out side and plug it in, put some bleach in it and let it run for a few minutes. then wash it out and run the rest of it out.
Dec 16, 2007 | Vicks V5100N Humidifier
Crane Cow Humidifier Logo
394 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
solver2010
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
