Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
How can I retrieve the CID's on my phones- - Uniden DECT 6.0 Cordless Telephone Expansion Handset
I found the manuel and the problem resolved itself after reading one or two pages in a few seconds
Posted on Feb 09, 2010
How do you retrieve the last number called to this phone?
If you have a CiX system with Caller-ID, a Caller-ID "review" or "log" key must be assigned on the set. Also, a CID buffer of (x) calls must be assigned in system programming. Once done, to review calls, press the CID Log key, scroll up and down using the NEXT/PREV soft key. This does not work on the older DK systems.
Dec 16, 2015 | Toshiba DKT2020SD Phone
Retrieve a phone number from earlier today from the caller id
If you're running on a CiX or CTX platform, you're dealer or system administrator needs to enter the amount of CID calls to be buffered on that particular phone. This can only be done via the System Administration Program. You'll also need to program a "Caller-ID Log" key
Sep 09, 2014 | Toshiba DKT3207-SD 1-Line Corded Phone
I have a CS6114 and don't know how to retrieve a missed call, please help. Thanks
While the handset is not in use, press down/CID to access the call log. Press up/down to browse the list.
Full details are in the "Call Log" section of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/1624/UserManual/5352/cs6114_manual_i6.pdf
Aug 30, 2011 | Vtech Lands Phones
How can activate caler id in panasonic kx-t7730
CID comes from a card installed in the phone system, CID service from the telco, and programming of the system, and your phone has to be ringing to display CID. If others have CID and you don't check ringing first. if no one has CID, then check to see if you have the card in your system. It will have a part number ending in 93 as in 62493, 82493, 84893, etc. and be installed inside the cabinet. After that, your Programming manual will have instructions on how to make it work.
CID only works on TA-624 and higher systems.
Carl
May 19, 2011 | Panasonic KX-T7730 Corded Phone
I want telephone number to be display when there is a call from outside
Well, you need about 3 things for that to happen. Hardware, programming, and a ringing phone. If others in your system have CID or you see CID when you're talking on the phone line, then it's probably just ringing. If nobody gets CID, then did you buy the CID card (part number ending in 93)? Once you get the card, you still have to tell the system that you're using CID.
Carl
Dec 30, 2010 | Panasonic KX-T7633 Corded Phone
I installed a caller id card in my kx-ta624 panasonic system in my home. The manual I have describes kx-t7030 phones with a caller id indication button but my phones kx-t7730 do not have a button and so I...
You get to program it :-)
In the User's manual section 2-2 there's an alpabetic index for Caller-ID. It requires 2 buttons, a CID-Indicator and a CID-Select button. We usually put them as the top 2 buttons in a 773x series phone, but you'll have to pick 2 adjacent or similar CO buttons. You label them CID-I and CID-S. Then you program them for either 96 and 97 or 6 and 7. You also have to tell the programming that you are setting up the common CID if you use 96&7.
Carl
Dec 12, 2010 | Panasonic KX-T7730 Corded Phone
I have a GE CID Speakerphone 29897GE1-A. How do I retrieve messages remotely?
Hello I want to change the configuration of the telephone but not as in addition to change the message of Englishman's welcome to Spanish or as with it the manual in Spanish. Thank you
Nov 09, 2010 | GE 29897GE1 Corded Phone
How do you activate call display on the Norstar M7310 phone system. email me a elainedrew47@hotmail.com Thanks you
CID call display requires 3 items, CID service from the telco,CID trunk cards, and maybe a software upgrade. If you program it and it doesn't work, then you need a CID trunk. If your software is in the neighborhood of 4, then you may need to upgrade to get a display on all phones when the phone rings.
Carl
Nov 18, 2009 | NorStar M7310 Corded Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
75 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
