Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
When I try to open files recovered from a floppy disk, I always get the error message "Unknown File Format." Is there anything I can do?
  • Sheldon Dreilick Feb 09, 2010
    Poems that I had on a floppy disc that I couldn't access anymore. I downloaded a program that recovered the poems to the user folder in Documents and Settings. Now I try to open these recovered poems and I either get "Unknown File Format" or the file opens and it's just rows and rows of gibberish.
  • marios basileiou
    marios basileiou May 11, 2010
    What are the files you try to open?the extension ?.*?
    Sniper:
  • 79 Answers
Try using backup and restore
click on restore and then click on advanced restore
select the path and click on restore
Posted on Feb 09, 2010
  • 617 Answers
Http://www.helpwithpcs.com/tipsandtricks/formatting-floppy-disk-win-xp.htm
There are two different formats,this article explains how to format the two so you can read them.
Why am I getting an Image Database File error on my Sony camera?
Would have been easier for me, when you had given the model number, but I give it a try. Most of the time you get these messages, when the file number is exceeding 999 or 9999. Or when the card or disk is full. Please try to recover all existing files from the memory (card and disk) and then try to format all memory devices.
Jan 30, 2015 | Sony Cameras
Hard drive does not recognize a file system
Buy a software called EASUS DATA RECOVERY WIZARD, install it on a working computer. Connect your hard drive as a slave and open the program. Use the Complete Recovery Method to recover all your files. It is usually pointless to try and recover system files. Unless you want to recover your documents and files that were there in the hard drive.
Apr 03, 2012 | Iomega Computers & Internet
I have a Verbatim 500Gb (model #47566) hard drive. After defrag and clean up, when plugging in, I get a message that the disk in drive K is not formatted and would I like to format it now? I know that if I...
People often feel panic when I see this. If I format the drive, will I lose all my data? If not, how could I get access to my files?
My take is that you may have to format the drive (use quick format) and then use recovery software to recover your files.
Here's some information about file recovery, think you need to take a look, very useful
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 26, 2011 | Verbatim Portable, 500GB, USB, 5400rpm...
I always have failure to boot and have beep sounds. Already installed asus update v6.10.02, still shows overclocking failed on start up and requests to configure BIOS. My system includes: inno3D-FX5500...
1-Does your computer show any sign of response after power button press?
2-Is your power cable properly connected and have main power switched on both your power supply unit and the wall plug?
3-Is the 20/24-pin ATX power connector has been connected between your motherboard and power supply?
4-Can The standby power LED (Green blue) light up continuously after the mains power is connected? (Note: Both flashing and off are no good here)
Fix 1
(1) Isolate The power going into your system ( i.e. connect your system to the wall plug directly, without sharing the power with any other devices via power extension cable.)
(2) Check if the power supply and power cable functions correctly, and have the input of your power supply set to the correct position (either 100/110V or 220/240V, depending on your country)
(3) Please try replacing your power supply.
Fix 2
1. No POST
1.1 Please clear CMOS to have a try (refer to motherboard manual for details)
1.2 If the problem still persists, please contact your retailer for a check
2. There is error message during POST: BIOS ROM checksum error. Detecting floppy drive A media... Insert system disk and press enter
2.1 If the support CD supplied with motherboard is available
2.1.1 Please restart system and put support CD into optical drive, then the system will recover BIOS automatically using CrashFree utility
2.2 If the support CD supplied with motherboard is not available
2.2.1 Prepare a formated floppy disk, then unzip the BIOS file downloaded from ASUS website into the floppy disk.
2.2.2 Please restart system and insert the floppy disk into floppy drive, then the system will recover BIOS automatically using CrashFree utility
2.3 If it is not helpful after the troubleshooting as the steps 2.1 or 2.2, please clear CMOS( referring to the manual introduction)
Fix 3
Please try the latest BIOS. I recommend you to use AFUDOS to update BIOS. You need to unzip it to get the ROM file.
You should use the command as follows:
AFUDOS /i[biosname]
or, afudos /i A:\BIOSNAME.rom(if the BIOS file is in the floppy disk)
You can store your BIOS into a floppy disk or a hard disk with FAT format. Then, you will be able to use AFUDOS to access the BIOS ROM file.
If it is not convenient for you to use DOS and AFUDOS, you can try to use EZ Flash. You can save the BIOS file into a flash disk then boot the system and enter BIOS, then you can update your BIOS by EZ Flash which is in the BIOS Tools page. Please load the default settings in BIOS after you have succeeded updating BIOS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | ASUS P5VDC-MX Motherboard
My sandisk cruzer says it is not formatted. it contains all my documents but I cant open anything if i format it i will lose all my data help!!!
Possible Reasons:
1. Your USB flash is too old and can be corrupted with time went on. As you know no hardware can be life-long ever.
2. There are bad sectors in the specific area of the disk that is required for a file system, e.g. for a boot sector or the FAT table sector. Since such a drive is obviously not possible to use, Windows refuses to format it.
3. Sometimes, you cannot format the drive to the FAT file system if it has been formatted to a file system which is not recognized by Windows. Such a drive should be reformatted to NTFS first, and then to the FAT file system.
Solution:
Step 1: Try the problem USB on another computer (better be most common Windows OS). See if the device can be accessed normally. This way can clear the buffers and eliminate incompatibility. Sometimes it will let the error disappear and make the drive work normally again.
Step 2: If the first method still won't help. Try recovering the data with some data recovery programs first of all. If you are running Windows, you can use Data Recovery for Windows. For Mac OS X users, turn to Data Recovery for Mac
Step 3: After the files are recovered, then follow those steps to try format the error USB drive (connect the disk to your PC first). My computer -> Properties -> Manage -> Computer Management -> Storage -> Disk Management -> select the problem drive and then format it from here.
Step 4: It's not over. After formatting, try use the data recovery software recommended in #2 to re-scan the drive to see if you can harvest more data. Good luck!
Feb 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Apr 10, 2009 | Husqvarna Designer I
NOT FORMATTED
The error means 3 things:
1. Files format of the files saved on the Floppy disk is not readable on the OS or does not comply with the file format of the OS. So you really need to format it.
2. The floppy disk is brand new and you need to format it first.
3. The floppy disk is not working. Try a known working floppy disk.
Oct 12, 2008 | NexxTech USB External Floppy Drive (NEFD2)...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
54 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
