Lexmark X5470 All-In-One InkJet Printer Logo
Paul Baglio Posted on Feb 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark x5470 all in one printer-low ink level
I refill my ownlexmark cartridges. But I cannot reset the low ink level
prompt that comes across my computer and printer. Any suggestions.
  • 3 more comments
  • Paul Baglio Feb 22, 2008
    see above description
    please post solution
  • Anonymous Feb 24, 2008
    printer doesn't read the ink cartiridge. I put new ones in the printer
  • mrbillOR Mar 23, 2008
    Problem same as Pauls, tried calling Lexmark, they are no help, they only say that you need to buy new cartridges from them to solve the problem.
  • Anonymous Mar 29, 2014
    dont i am not sure if i can use these tesco cartridges in my lexmark x5470 printer
    dont want to break my printer
Anonymous
Level 3:
President:
  • Master 2,072 Answers
  • Posted on Feb 22, 2008
Anonymous
Master
Level 3:
President:
Answers
2072
Questions
0
Helped
1109840
Points
5835
Most likely the cartridge is no longer usable. The ports will eventually become to clogged or the fiber inside the cartridge will not permit the ink to make it to the port and not read as a full cartridge.
  • Anonymous Feb 22, 2008
    Buy a new cartridge
A
Anonymous
Iam trying to find a resetting chip/plastic mechanism w/ a1.5volt
battery similar to the one epson makes for its printers. i dont know
if one exists but ia am out there trying to find it.
tx Paul James
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Answers
29
Questions
0
Helped
17869
Points
35
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
906
1helpful
3answers
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Refilling the Lexmark x5470 color ink cartridge: Can't
There should be a dialogue box that pops up on your computer when the cartridge is low telling you to order new ones. Usually there is a box you can check to tell it to ignore that the cartridge is low. If you don't get the dialogue box, somewhere in your printing preferences you should be able to tell it to "ignore ink levels." There does not exist a cartridge that "does not contain this circuitry." There are no compatibles of these cartridges and all refills are of original manufacturer cartridges.
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
My lexmark will not work with refilled ink cartridges.
Lexmark is one of the best printers, Look to see if the heads on the printer are clean. Unlike most printers Lexmark cartridges dont do the controling, the printer does. My son replaces the cartridges, he doesn't refill because of the problem simular to yours.
Compatable black ink cartridge
Is the print out normal? If the print out is normal you just need to reset the software to know that you have a new cartridge.
If you open the printer cover, remove and then reinsert the cartridge you should have a message on your display asking you to align the cartridge. When you do this it will reset your ink levels.
If you are using a brand new Lexmark cartridge this should work find. If you are using a refilled cartridge then you will still see the cartridge as they are not supported on Lexmark products.
Thanks
Catherine
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
3helpful
2answers
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
1helpful
we have a link on how to fix your own printer through this link(check for search box further down page)
2answers
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
