Frigidare washer glws16491s
Dear Sir,
When I wash clothes and the washer starts to wash the water continues to fill the machine and wil not shut off. This also happens when in the rinse cycle. The water will run indefinately and over flow. I have to use the shut off valve to stop the water from running.
  • 5,911 Answers
The problem is usually associated to a defective pressure switch. Your pressure switch is located under the operator console and is a round, cookie-shaped device with an air hose and some electrical connecters (usually behind the water level or load level knob). If you can gain access behind the console, the first thing to look for is the clear plastic air hose. This hose should be connected to the switch. Sometimes the hose becomes loose and falls off. Often reattaching the hose will correct your problem. If the hose IS attached, you may have either, a hole in the hose somewhere, a dirty electrical connection somewhere, or your pressure switch is bad. Double check and make sure the pressure hose switch is intact and let me know. If you suspect you need to replace the pressure switch, you can find the part online at searsdirect.com or repairclinic.com (I'm sure there are other websites available, but these are one's I have frequently used). Just type in your COMPLETE model number in the Search menu and you will find a part listing with prices. If you need further assistance, please post back with your comments/concerns. I hope this helps you.
Posted on Feb 22, 2008
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Wil not start
you may have to center the tub and reset the off balance switch by opening the lid all the way and centering the tub
Feb 26, 2010 | Speed Queen AWS45NW Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Year old frigidare washer won't agitate
the selector switch might be out.
Aug 08, 2007 | Frigidaire FWTR445R
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
