Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher not draining
Water standing up in bottom of dishwasher after cleaning not draining water left standing after cleaning and drying cycle water does not drain from bottom after cycle is complete
  • 9 more comments
  • Rmax Mar 10, 2008
    Dishwasher will not drain, could the control have a problem or should I consider replacing the pump.
  • Anonymous Jun 16, 2008
    dishwasher will not drain
  • fbodine Jun 26, 2008
    it wount drain
  • Anonymous Jul 23, 2008
    After completed cycle water is left in the bottom of washer
  • shamburg Aug 06, 2008
    I have a Kemore Elite dishwasher and it will not drain...water stands in the bottom..under trouble shooting in the manual, it only offers to make sure the drain cylce has completed...not MUCH HELP SEARS! I called Sears Service Repair and had a tech come out...he pulled it out and check the power to the water pump...His diagnosis...the PUMPS BAD....$287 to repair...I did not have it repaired....trying to figure out if there are instructions on how to pull it out and replace myself....Tech said the part is $87.....Anyone know how to pull it out and replace?
  • cdlewis1540 Aug 12, 2008
    I have the same problem. I checked the drain hose and it is not blocked.
  • Tandem Aug 30, 2008
    17808 wont drain
  • Anonymous Oct 14, 2008
    Our dishwasher is only six months old and is having the same problem. The cancel / drain does work, but is this caused by a defective part? We are calling Sears due to it being under warranty, but thought all cases should be posted for reference.
  • sailingrich2 Feb 04, 2009
    dishwasher is 1 year old and does not drain at the end of cycle
  • Anonymous Mar 14, 2014
    Will drain but leaves about a half gallon of water in bottom of dishwasher
  • Anonymous Mar 28, 2014
    too much water left in bottom of washer
    President:
  • Kenmore Master
  • 2,651 Answers
Try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE:
GE dishwasher PDWT480R10SS does not fully drain at end of cycle
you need to clean the outside edge of the disk at the bottom of washer and put high heat silicone around the outside edge and let it dry 24 hours before use, if it still doesn't drain all the way ,you will have to replace the disk. I have repaired many of these . good silicon should do it.
Sep 14, 2014 | GE Dishwashers
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
So it sounds to me like it is your "pump" I work for an appliance parts dealer and it looks to me like the pump you need is originally part# 99002750 but then it changes to #6-917641....It runs about $57.00 and you can find this product at www.allbrandonline.com
Hope this helps!
www.appliancepartsonline.net
Dec 14, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Standing Water
are you leaving it long enough to finish it's programme or are you opening it when the drying light is on as some dishwashers leave a bit of water in the bottom to help with the drying programme
Dec 08, 2007 | Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
2,708 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
