Question about Asko D1876 Dishwasher
Asko d1876 (black)- despenser problems
The dispenser doesn't close as it used to, it doesn't close as i put soap in and stays open, if i try to force it it makes a sound. I just got the new part and installed it, still same problem, so it makes me think it is something electrical behind in the system somewhere, anyone has a helping hand?
    Sergeant:
  • 351 Answers
It sound like you need a new pcb,if the dispenser is making a buzzing sound,then thats it remove the control panel and see if the tracking is burnt anywhere,also replace the wax motor on the drying vent.
Posted on Mar 02, 2008
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
The soap despenser is broken. looks like the spring is inside the holder and it will not close....stays open at all times. model number for our dish washer is 665.13842k601.Kenmore ultra wash. is this an...
heatman101 '';
Aug 01, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
Soap dish won't stay closed after I fill it.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 09, 2011 | Asko D1776 Built-in Dishwasher
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher detergent dispenser compartment does not automatically open
You need a new PCB for your machine. And a wax-motor. Maybe a new dispenser too.
Jan 28, 2008 | Asko D1876 Dishwasher
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
199 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
