Question about Superstar Radio Communications
Off frequency by 1khz on USB only Rest of the radio works fine. Thanks Ian.
  • 494 Answers
There is usually three voltage adjustment points for AM, USB and LSB, these look like small, square metal cans not all that far from the channel knob. These are not usually marked and will vary from radio to radio as the chassis are different. A scope or analyzer is needed to do the proper adjustment. but listening to a known good signal source can do the same. Not for the novice, leave it to a technician.
Posted on Feb 13, 2010
AC-MX36 tuner has 1kHz whistle
There is a feed back circuit in tuners to control input signal within the tolerated frequency. Some thing has gone wrong there. A capacitor must be leaky or open.
Aug 21, 2012 | Televison & Video
Cobra 19 DX IV, I bought this unit in america, but i live in the U.K. and can't pick up any channels, does this unit Only work in america, can i get somthing for it to work in england??? Thanks...
  • The UK uses more FM frequencies than AM frequencies. So the CB will work over there just fine but you will need to find someone who uses them frequencies as well or it may no be much fun. Here is a frequency chart for what we in America call import radios shipped from over there. http://macuk.org.uk/cbchart.htm 27.555 FM is the main frequency used in the UK but the Cobra 19 is a strictly AM CB. Also on the link on the far right are the standard 40 channel frequencies from the UK version of CB's and not one is the same as the Cobra 19 as the UK uses FM for their 40 channel CB radios.
  • Here is the 40 channel CB frequency chart utilized in America http://www.csgnetwork.com/cbradiofreq.html
  • Hope this clarifies things for you.
Regards, Tony
May 18, 2011 | Cobra 19 DX IV CB Radio
Frequency counter displays two digets high from hump on fine clarifier adjestment on usb.27.186 insted of 27.185. also in am mode shows dead on with clarifer hump until mic is keyed thin dropes from 27.185...
Turn that fine clarifier a 1/4 turn or so to the right. I own a Galaxy DX99V and sometimes if that clarifier is just right it will drop down a hundredth of a MHz just like that when the mic is keyed. Your radio is just fine. Just adjust that clarifier a tad. The Galaxy DX99V is one of the best radios out there. I love them. -73-
Mar 10, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
SSB ALIGNMENT
You'll need to connect Frequency Counter to C252 & adjust:
USB Frequency: 10.6975Mhz adjust L126 in receive mode
LSB Frequency: 10.6925Mhz adjust L127 in receive mode
May 04, 2008 | Magnum DeltaForce CB Radio
I can't pick up anything...
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Oct 04, 2007 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Communications Logo
61 people viewed this question
Top Superstar Radio Communications Experts
AnyMHz.com
AnyMHz.com
yobo007
yobo007
cwradio73
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
