Question about Ricoh Aficio BP20N Laser Printer
CANNOT FIND METER COUNTER ON MACHINE?
WHERE DO READ THE METER COUNTER FOR COPY USAGE ON THIS MACHINE?
Bp20n does not have a menu button only has a cancel button....... next
Posted on Sep 10, 2008
  • 87 Answers
Print a configuration page. It will be on there. Menu, lists/prints, config page.
Posted on Feb 23, 2008
How to get meter read for konica magicolor2490
Push the Display button
This will show the toner levels.
Push the down arrow to toggle through the copy counts (B/W & colour, copies, faxes, scans etc).
If you are looking for the instructions in a PDF manual search for "counter" instead of "meter".
Jan 10, 2014 | Konica Minolta magicolor 2490MF Laser...
Where is the meter read button on the canon 1025?
hi sir, nothing counter / read meter button on this copier, and you can see at the mini LCD only.
to see reading meter you press the star button (*) than you press (>) or (<) button to find a counter than press (ok) button.
good luck
Jun 24, 2011 | Canon imageRUNNER 1630 Copier
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
What is linear counter balance,What is the
It much smoother more control usage than bushing smith machine that will drag
May 15, 2010 | Yukon Linear Counter Balanced Smith...
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
Control card for our minolta ep2030 was shorted out
You will most likely have to by a new key counter or copy controler. Try to find a used one on e-bay. If you just want the copier to work again. In the cut wires with Minolta two of the wires need to be jumed to close the circuit, so the counter will not lock the copier up. You will have to guess, I don't know what color wires were used? Jump two and see if the copier gets released.
Jan 26, 2009 | Office Equipment & Supplies
7310HP meter reading
THERE IS NO SPECFIC READING METER IN PRINTER BUT IF U WANT TO SEE THE USAGE JUST PRESS THE MENU BUTTON AND REMOVE THR PRINT LOG
BY PRESSING THE MENU
Oct 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
How to repair with Toshiba copier 2060
lan lam... "insert key counter" means that the machine has an external control device. Usually a small box the size of a pack of ciggerettes or smaller) with a mechanical counter that needs to be inserted into a port on the machine in order for it to operate. Companies used this to "control" and/or track machine usage by department or person. It may be that your machine has one but it's not inserted well enough, or you are missing the counter comepletely. If you don't have one of these control devices, you will probably need a certified technician to come out and disable this feature.
Oct 09, 2007 | Kyocera RI-3530 Black and White Copier
Ricoh Aficio BP20N Laser Printer Logo
701 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
