Question about Philips 47PFL3603D LCD TV
MY TV HAS SMOKE COMING OUT FROM BACK WHAT DO I DO
  • lzepeda Feb 08, 2010
    Not cool its not even 2 years old
    so this has nothing to do with the backlight inverter? wow this is crazy but it happens i guess thank you
    Problem Solver:
  • 18 Answers
Bummer, hopefully its under warrenty still, if not, then you need to shop for a new one
Posted on Feb 08, 2010
  • rpmccann Feb 08, 2010
    I am so sorry to hear that, this does happen to too many flat screens, usually due to dust buildup inside (not easy to clean) which in turn causes too much heat build up, then parts fail, I woudl highly recomend you add a computer fan or two to the back of your replacement, to prevent this from happening again, and / or at least blow the dust build up out of it every 3 to 4 months. I have seen this failure occure in as littel as 9 months (in homes with fireplaces / dusty enviornments / or smoking homes, as a side note, Apple COrp will deny warranty repairs on any of their electronics that have any kind of smoke residue build up inside of their cases (due to smoking while computing) and its not even listed in their warranrty agreement! Due to smular damage from heat build up
    your very welcome, I wish I had better news for you. Unless you are an expreianced relectronic tech then I do not recomend you attempt to repair it,(due to residual high voltage even after its unplugged) but if you do "dabble in electronic componet repair" and are aware od how to do it safly, then watch in your local "Craigs List" or check your local recycling center for the same or simular model TV, if you find one (for very low cost or free) then pick it up, and try swapping parts, you might be lucky, you can kill the smoke oder out using "Fabrese" but must use it very gently, and let it air dry for at least a week before plugging it back in. In case you are wondering, I was a componet level repair tech for the past 37 years, recently retired (just so you dont worry I am just "blowing smoke" to quote a good old phrase, Again best of luck.
Smoke coming back
The main dc reservoir in the power supply must have burst. This capacitor 47 to 100 MF/400V also releases lot of smoke when it bursts. Most of the times you just have to replace it and the tv works fine.
Aug 23, 2013 | Samsung LN32A330 32 in. LCD TV
Smoke from plasma TV
Sounds like you will need a new power supply board you can get the power boards from www.tvrepairworld.com which also has instructions for replacing the board. Just hit the contact us button on the right side then enter your model number and symptoms a samsung tech will respond via email to assist you with the issue.
Jan 23, 2012 | Samsung 50 in. Plasma TV
Screen went black smoke coming from back tv is 2007 according to back sticker still have sound
Smoke = overheating = big short = big failure of a part.
Unplug the tv immediately - you don't want t set your house on fire - and call a repaiman. Since the tv has been smoking then the damage will be extensive - a lot of parts, even entire boards, have been damaged. Te repair will be costly.
Oct 05, 2010 | Element Electronics FLX3210 32 in. LCD TV
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Mar 15, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Flyback shorted, trying to replace
astimagnetic.com:flybacks.video heads,laser pickup and more...
Jul 08, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Smoke coming from the back
power board shot. remove power board and purchase the exact board with the numerical stamp on the board usually 12-16 characters. make sure it matches, replace board and reasemble tv and enjoy.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
Burning Smell with Samsung HC-p5241w
dont fear the smoke behind. firstly open your tv. get a brush and clean the in side,it might be other particals dropped in side.
you are able to see where the smoke is coming from.
a qualified tech will solve that without wasting time on it.
Jan 07, 2009 | Goodmans 257NS 20" TV
White smoke coming from the back
i advice you don use this anymore and contact one authorized service to fix that problem there is an supply problem and could go worst
That smoke could be from one component like one rezistor or electrolitic capacitor but you cant fix that yourself
Dec 10, 2008 | RCA D61W20 61" Rear Projection Television
Turns on then right off after a click saw smoke coming out of tv
check the board, maybe is burned , I have the schematics, if you want it, write me to ipbass@gmail.com, only I need the model of the board
Mar 03, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Philips 47PFL3603D LCD TV Logo
2,669 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
