Question about Sony Dvcam DSR-250 Camcorder
Don't have the service manual and there is a tape stuck in it and need to eject it. any ideas?
  • nkroh Feb 08, 2010
    Got the tape out with the help of my boss but still get the same error code and no funtions. don't know if something is broken or just needs a reset of sorts.
Well, never found the solution myself, I had to sent the unit out to authorized Sony service.
Posted on Feb 09, 2010
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Feb 09, 2014 | Denon DRR-M30 Dual Cassette Deck
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
I have a tape stuck in my drive and I can't eject it either on the hardware or using back up exec. The folloing lights are on Green power is on, orange status is on, and red error is flashing Any ideas how...
The only option for you is to remove the tape drive from your server, open it, and manually eject the tape that is stuck. This is not easy to do. Maybe it would be better if you remove the tape drive from the server and take it to a repair centre.
Oct 26, 2009 | Dell Computers & Internet
Funai tv/vcr combo has a tape stuck
It shuts off due to an error or mechanical problem, this is a safety feature. Sounds like the gears are worn/stripped and needs to be serviced/replaced. The tape can be remove by opening the unit and manually ejecting it if its important to you.
Aug 06, 2009 | Funai F3819D Combo
BANG AND OLUFSON BEOCORD V8000VIDEO RECORDER TAPE WILL NOT EJECT
turn the motor pulley at the far right corner this is the load/unload motor.unfortuneately the gears in this assy are often the cause for a jammed tape.take to any vcr specialist as the deck is a phillips (turbo) model and well known to engineers.
Apr 15, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Jul 25, 2008 | Certance (CL1001-R) Ultrium Tape Drive
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
https://www.usa.canon.com/internet/portal/us/home/support/details/camcorders/support-minidv-camcorders/zr
Apr 15, 2017 | Video Cameras
Zr100 tape stuck
TAKE IT TO NEAREST SERVICE CENTER TO FIX THE PROBLEM. NO WAY TO REMOVE THE TAPE MANUALY
Dec 03, 2007 | Canon ZR100 Mini DV Digital Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Sony Dvcam DSR-250 Camcorder Logo
131 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
