Question about Philips SmartTouch-XL HQ9190 Electric Shaver
Seems to run very slow. Battery is fully charged, head is cleaned
  • shaveroutlet.com
    shaveroutlet.com May 11, 2010
    remove the head assembly and turn on the shaver. press the palm of your hand against the three gears and press reasonably hard to try to stop them from turning. do they stop easily or do they continue to turn in the palm of your hand? when you charge the shaver, does it run for several uses or does it run out of power quickly?
Thank you for your help. I bought a Braun, and threw that hi-priced junk out. I believe it was the best solution. Thanks again!
Posted on Feb 09, 2010
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
SLOW STARTING
Clean battery connections, and/or check the battery to see if it retains a full charge. Fully charged batteries are normally holding a 13volt charge, and up to 14.5 volts will show on a gauge during charging
Jan 09, 2015 | 2005 Kia Picanto 1.1
Get my Jeep out of Park if it is locked in that position
what jeep? what year,? 1946 willis jeep? no , its a stick but .....
this is park lock out feature failing
if the battery is not charged, nothing much works.
12.6vdc, rested, no running, is correct. ,less is bad or discharged.
below 11v many things give up the ghost.
wow, no mention at all of all the other things.
car starts. and engine runs, ?
head lights work.?
etc.
checked fuses yet>?
park lock out if bad.
is fully covered in the FSM
or alldata.co
charge the battery fully, first.
then test car.
Dec 23, 2014 | Jeep Cars & Trucks
I got a 69 chevy c10 the starter wire grounded to the exhaust fixd that then it wuldnt charge so changed the voltage regular then starter & silaniod seems like its holdn a charge but still wo
Hey Steve, if you need a jump to start it then every thing is working except battery holding power try putting battery on a SLOW charge for a day then try again when its running check output of altinator with a fully charged battery it should be 12.5-13.5 volts and rise when you rev motor up ,when you jump it im thinking the battery is very low and the altinator is trying to recharge battery and it cant do that in just a few minutes running time or take it on along ride and watch amp gauge .good luck Steve.
Woody
Oct 05, 2014 | Cars & Trucks
Motor runs slow
I'm sure your talking about a NiCad battery. It will show full but once it has a little age it won't hold and deliver a full charge. Recycle the battery and buy a new one.
Feb 08, 2014 | Hitachi Saws
Slow to start like in starter
First, make sure your battery is fully charged.
Next, check your plus and minus connections on your battery posts. Don't just check them, clean the clamps on the inside and the posts. They make a tool that is a battery post wire brush tool for under $6 bucks, get one so you can clean them well. This may help the issue.
Once they are clean and it still is slow starting, my conclusion would be you may have a bad starter. The slow start means you typically have a dead spot on the starter armature which you cannot do anything to fix, replace it. .
Their is only other reason it could be slow to start and that is if you had a compression issue, and your car actually runs, so that is not it.
Nov 24, 2011 | Lexus LS 400 Cars & Trucks
My 1993 cadillac eldorado is cranking slow and i just change the alternator
If the battery is fully charged but the starter is slow, the starter may have an internal short or may just be worn out. Make sure your battery is fully charged and the battery terminals are clean and tight though before buying a new starter.
Sep 08, 2010 | 1993 Cadillac Eldorado
Just bought car. battery seemed to be dead. charged up and drove 1-2 miles while check charge light was on with change oil and check coolant. Also, red light on dash for Alternator. Then all lights guages...
sounds like the alternator is shot and is not supplying sufficient power to the engine or even enough to charge the battery, try replacing it, and you said the dash light for the alternator is on so its most likely the alternator
Oct 29, 2009 | Oldsmobile Aurora Cars & Trucks
My roomba 4150 is running very slow. It is fully
may need to clean inside.the wheels pick up trash and deposit it on and near motors.also try to take ends of roller brushes off and clean hair ect.
Jul 09, 2009 | iRobot 4150 Roomba Vacuum
Philips SmartTouch-XL HQ9190 Electric Shaver Logo
232 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
