Question about HP LaserJet 1018 Printer
The paper was jammed, I pulled the paper in the direction that was not suggestted by the user's manual. The printer does not print any more (no paper feed).
  • 5 more comments
  • jinghai_zhen Feb 08, 2010
    I have unplugged the printer several times before and it didn't work after it was re-powered.
    There is no button on the HP LaserJet 1018 and there are only two lights (one green one oringe).
    Please advise me what to do.
    Best,
    Jinghai
    I was using an HP LaserJet 1018 printer. Yesterday, the paper was jammed, I pulled immediately the paper in the direction that was not suggestted in the user's mannual. The printer does not print any more (no paper feed).
    Looking forward to hearing from you!
    I couldn't see anything wrong with the paper feed rollers. I have looked at them several times, not sure how to check and where exactly to look though.
    When I checked the printer configuration, I cannot configure the port at USB1....
    Could that be a problem?
    Sorry it didn't work. Any more suggestions?
  • jinghai_zhen Feb 09, 2010
    I have removed the pick-up roller several times and it doesn't look like to be the problem.
    The problem started just after I pulled back a jammed paper that was jammed only at the front edge. It shouldn't be possible to damage anything such as the pick-up roller.
    However, I noticed that one could see a loose handle on the left handside in side the printer, which can be seen when the cartrige was removed. I wonder if this small handle should be loosely attached to the left.
    President:
  • 3,278 Answers
Hello, Jinghai.
Sounds like you may have damaged the pickup roller.
To replace the pickup roller:
Order part #: RL1-0266 In the U.S., call 800-471-4701.
Changing the pickup roller (from HP Support):
1. Turn the printer off, and then unplug the power cord from the printer. Wait for the printer
to cool.
CAUTION To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper.
2. Open the print cartridge door, and remove the print cartridge.
3. Find the pickup roller.
4. Release the small, white tabs on either side of the pickup roller, and rotate the pickup roller toward the front.
5. Gently pull the pickup roller up and out.
6. Position the new pickup roller in the slot. The circular and rectangular slots on each side will prevent you from installing the roller incorrectly.
7. Rotate the top of the new pickup roller away from you until both sides snap into place.
8. Reinstall the print cartridge, and close the print cartridge door.
9. Plug the printer into the power outlet, and then turn on the printer.
But, first try to clean the pickup roller - that may work. Here are the instructions:
If you want to clean the pickup roller rather than replace it, follow the instructions below:
1. Remove the pickup roller as described in steps 1 through 5 of Changing the pickup roller.
2. Dab a lint-free cloth in isopropyl alcohol, and scrub the roller.
WARNING! Alcohol is flammable. Keep the alcohol and cloth away from an open flame. Before you close the printer and plug in the power cord, allow the alcohol to dry completely.
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt.
4. Allow the pickup roller to dry completely before you reinstall it in the printer.
Hope this helps.
Posted on Feb 08, 2010
  • 421 Answers
You have probably damaged the paper sensor that detects the paper in the paper feed path. It's usually a small sprung metal arm that "feels" the paper as it goes through. Once damaged the printer won't know that paper is in the feed path and subsequently won't print. Find a good shop locally that can have a look and attempt a repair for you.
  • 542 Answers
Check that whether the paper feed rollers have been damaged or gone bad while removing the paper jam. Also check any peice of paper left inside the printer and it shows paper jam signal.
Revert back for more assistance. Also give your valuable feedback/rating for the solution provided.
  • 1 more comment
  • Rajesh Pai
    Rajesh Pai Feb 08, 2010
    Go to the below mentioned website will describe how to resolve this problem.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • Rajesh Pai
    Have you gone through the Website Which I posted earlier. In that site, clearly explained about your problem.
  • Rajesh Pai
    Rajesh Pai Feb 20, 2010
    I have not got any update from you? Hope your problem got resolved.
    Revert back for more assistance and give your valuable feedback/rating for the solution provided.
    Thank you for using Fixya.
    President:
  • HP Master
  • 2,923 Answers
Try to power cycle the printer. First, disconnect the printer from the wall socket and leave it disconnected for five minutes. Then turn the printer back on.
If that did not work, then cold reset the printer. Here's how:
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancel buttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison.
The printer is now reset and ready for use.
Good luck and have a great day!
  • Melvin Ramos
    Melvin Ramos Feb 08, 2010
    Can you check the printer properties? Kindly follow the steps below:
    1. Go to Control Panel > Printers > Make sure that the HP LaserJet 1018 is set as the default printer.
    2. Right-click on the printer icon > select "Use printer online".
    3. Right-click on the printer icon > Properties > Ports > make sure that "USB001 Virtual Printer port" is selected.
    4. Be sure that the printer name is next to USB001. > Apply or OK.
    5. Try printing a test page.
    Please let me know if there's any unusual setting that you will see.
    Thank you!
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
Says there is a paper jam and to open top cover but I do not see a paper jam there. I took out the toner cassette but do not see the paper jam.
When your reports paper jam for any reason, whether there is paper jam or not, most times you need to go thruogh paper jam clearing procedure to have your printer printing again. So please follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Put off the printer and unplug it from its power source.
Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
(If the printer is a DeskJet, otherwise ignore this step) Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer's mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
(If the printer is a DeskJet, otherwise ignore this step) Return the cartridge gently and press it firmly inside so that you here it snap inside.
Close all covers at the top, front or back.
Power on your printer and you should be able to print again.
Good luck and God bless!
Mar 04, 2011 | Kyocera FS-2000D Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I can't erase PAPER JAM
Did you take out the trays to see if paper is stuck/jammed under the print mechanism? Check to see if torn paper is in the rollers?
Feb 06, 2010 | Brother MFC-5840CN All-In-One InkJet...
My indicator is showing a paper jam and I have cleared all paper that I can see from the feed area. It still instructs to clear the paper jam. Do I need to try to get inside the box and if so - how should...
Once some printers report paper jam, you most must go through certain procedures, even if you have removed the jammed paper, for the printer to print again. So I suggest you follow this procedure:-
i. Put off the printer and unplug it from its power source.
ii. Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
iii. Site the paper (if any) that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer’s mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
v. Close all covers at the top, front or back.
vi. Power on your printer and you should be able to print again.
Dec 19, 2009 | HP J4680 Office Jet All-In-One Printer
PAPER JAMMED-PRINTER HL5150D
Hello a_bowen1
You can clear the jammed paper as follows.
Note
    • If a paper jam occurs when using the optional lower tray unit, check for correct installation of the upper paper tray.
    • Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and reduces paper jams.
  1. Pull the paper tray completely out of the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Press the cover release button and then open the front cover.
  1. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
hl50_05712.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Note
    If you have to pull the paper toward the back of the printer, the fuser may get dirty with toner powder and it may scatter on the next few printouts. Print a few copies of the test page until the scattering of toner stops.
chap0615.gif Caution
    After you have just used the printer, some internal parts of the printer are extremely hot! Wait for the printer to cool down before you touch the internal parts of the printer.
  1. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
  1. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
  1. Pull the Duplex Tray completly out of the printer.
  1. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
  1. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
hl50_047.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit assembly back in the printer.
  1. Put the paper tray in the printer.
  1. Close the front cover.
Good Luck and don't forget to leave a rating based on my solution:
Mark
Apr 04, 2009 | Brother HL 5150D Laser Printer
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
99 people viewed this question
Seeker5211
Seeker5211
