Question about Dell 0Y3740 Keyboard
The number keys won't work, the ones located on the far right of the keyboard/calculator area....
    President:
  • 2,923 Answers
  • Disconnect and reconnect your keyboard if it is external. Make sure that the connector is completely inserted into the port. (USB plugs fit into ports one way only, and won't allow you to make a connection if you try to connect them in upside-down.) Test the keyboard again.
  • Connect your keyboard to a different USB port.
  • Try a different keyboard on your computer if possible
If same problem occur even though the keyboard is connected in a different computer, then you need to contact a local repair tech and have it repaired.
Thank you!
Posted on Feb 08, 2010
  • 415 Answers
Try clicking the NumLock (or NumLck) button located above those numbers. Click it once and a light will come on. Then you can use the number keys.
    President:
  • 2,678 Answers
Turn number lock on
No numlock key on MX5500 logitech
The ten-key keypad is used for the calculator too. The button to swith between these modes is just aboc=ve the key and has a picture of a calculator. To use directional arrow keys, this keyboard comes with it's own separate arrow keys located under the delete button. They felt no need for directional function, number input function, and calculator function.
Aug 16, 2014 | Logitech MX5500 Keyboard/Mouse
Negative number
Use the "(-)" key, located on the bottom row of the keyboard, between the "0" and "=" keys.
Sep 30, 2013 | Sharp el-531x scientific calculator
What are the names of kyboard and its keys ?
it is only for a computer keyboard hope it help from you.
A computer keyboard serves as a main operating tool for accessing and inputting data into a computer. The keyboard features many functions and keys that a user may never use, but is still essential to some users. Understanding the keyboard can improve computer knowledge and use.
QWERTY Pad
The "QWERTY" pad is main sections of letters on the keyboard. These letters are mainly used for typing and also as shortcuts in programs like Windows Movie Maker, Adobe After Effects and computer games.
Number Pads
The far right side of the keyboard features a number pad that resembles a calculator. This number pad is essential for programs like Excel, but can also be used to input numbers as a typing function. More numbers are just above the "QWERTY" keyboard that also feature symbols when the "Shift" button is used.
Arrow Keys
The right bottom of a keyboard features four directional arrow keys. These keys provide navigation through word processing documents and also serve as scrolling functions in web browsers.
F Bar
The top of a keyboard features the "F Keys," a selection of keys that extends to "F12" on most keyboards. These keys serve different functions. For example, "Alt and F4" exits out of a program. "F1" will start the typing helper in word processing programs.
Extra Keys
New keyboard feature shortcut keys at the top of the keyboard. These include shortcuts like "Power," "Sleep Mode," "Calculator," "My Computer" and "Web." Some also include media controls for movies and music.
Aug 11, 2011 | Acer NSK8458AN Keyboard
The numbers 1-3 on the keypad wont work
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Jun 03, 2010 | HP 48gx Calculator
NUMBER 8 BUTTON WON'T WORK
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
May 27, 2010 | HP 48gx Calculator
My number keys are not working, keyboard calculator right side, I just purchased this keyboad, Friday April 2, 2010. I need help!
the numlock key must be enabled to use those keys..check it out whether it is enabled or not....otherwise it is a faulty one...get it exchanged...
Apr 05, 2010 | Microsoft Wireless Laser Mouse 5000
My HP48Gx has a problem with the last keyboard column(F L R X arrow / * - +). It stops working and if you shake it then it will work again. Any ideas?
Warning
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Feb 04, 2010 | HP 48gx Calculator
Replaced batteries. Displays only
The following procedure allow you to verify the good working order of you calculator. One of the tests concerns the keyboard.
In the keyboard test, make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs.
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
Hope it helps.
Thank you for using FixYa.
Nov 22, 2009 | HP 48gx Calculator
The 7, 8 and 9 keys do not work on my 48sx. The
In the keyboard test, make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
Nov 17, 2009 | HP 48gx Calculator
I cant use my number pad on the right side of my keyboard.
Have you tried pressing the NumLock-key?
It is located right above the key "7" on the numpad/calculator pad.
Dec 17, 2008 | Logitech Cordless Desktop MX3200 Laser...
Dell 0Y3740 Keyboard Logo
518 people viewed this question
Alun Cox
