Question about SanDisk Sansa e260 MP3 Player
My mp3 player is not charging
When connected it shows that is charging but when it is disconnected it has not charged how can i rectify this ?
  • 201 Answers
Try other USB ports on your computer, especially one on the back panel. Leave it there for several hours. You can also try an AC adapter.
Posted on Feb 09, 2010
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
I have an Curtis MPK4099UK MP3 Player. It says to charge it I need to install setup.exe from the CD. After I done that I restarted my computer then I put My MP3 Player on charge,(with the on switch) It...
I had the same problem but have now resolved as follows. Turn the top switch to on and connect via USB port. Picture should come on the mp3 player indicating it is connected. For some reason unknown to me in order to charge you need to turn the MP3 player on - but this is impossible if there is no charge. What you need to do now is leave the MP3 player connected like this overnight - it will then have gained enough charge in the morning so that when you then disconnect the MP3 player from the USB lead you are able to actually turn it on. PLEASE NOTE this is not turning on by the switch at the top. What you do it press and hold the circle/dash symbol i.e. at the bottom of the white keypad bit on the front of the MP3 player. As you then let go it comes on. Let it finish turning itself on, then reconnect to the USB lead and leave over night to get a full charge. Good Luck
Sep 25, 2010 | Curtis MPK2066 MP3 Player
I bought a Gogear 2gb philips SA018 mp3 player i dont know how to start it and download anything theres no instructions and its not showing anything. how do i charge it?
I have problems with the Philips SA018 4gb MP3 player. While it is connected to the computer the it shows green once it is disconnected it goes red and nothing works.The battery should be fully charged as it shows green,but as I have said once it is disconnect it turns red and that's it...there is no joy.I wonder is there a problem with the battery...? Has anyone else had this kind of issue?
May 21, 2010 | Philips GoGear SA178 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Sansa c250 mp3 player connects and will not charge
It takes a while. Try leaving it charged over night, then tell me if you have any problems.
Sep 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
When i take off charge
That is normal behavior for the player. The functiosn only work AFTER you've disconnected it from the computer.
-Tha Mp3 Doctor
Oct 27, 2008 | SanDisk Sansa Clip MP3 Player
PC not detecting mp3player and also not able chage
Hello dear
If u can open your mp4 player then open it. and after change the crystal
detecting problem will be slove.
thanks
Sep 08, 2008 | Philips SA5125/37 MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
44 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
