Question about Xerox Phaser 6120/YN Laser Printer
Changing black toner cartridge - Xerox Phaser 6120/YN Laser Printer
  • 415 Answers
To change your toner first turn off the printer and unplug it from the power outlet. Then, lift the toner door. Carefully grap the toner cartridge from both ends and lift it up. Do not shake the toner as you may get dirty. Then take the new toner cartridge, remove any plastic covers and insert it in the printer. Close the toner door and start your pritner.
Posted on Feb 08, 2010
  • 300 Answers
SOURCE: Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
Posted on May 18, 2008
  • 3 Answers
SOURCE: Xerox Phaser 6125 Color Printer
ur black ink tank is empty and ur only color tank is printing
Posted on Sep 20, 2008
wrinaldo
  • 185 Answers
SOURCE: I AM CHANGING THE BLACK TONER CARTRIDGE ON A DELL
Either the "toner cartridge sensor" N4445 isn't reading the chip in the toner,
or an MCU board P5281 or EEPROM is defective
-Whit :)
Posted on Jul 31, 2009
brainschee
  • 23 Answers
SOURCE: My Minolta Magicolor 2500W printer indicates that
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Posted on Dec 11, 2009
SOURCE: We have a CM3522 printer. Just changed the black
check the consumables to see if the imaging unit needs to be changed.
Posted on Sep 01, 2010
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
When any color cartridge finish , you must change the whole unit Why?????
No, you must change only the toner cartridge that has finished. It would be quite a waste to replace a toner cartridge that's not empty. Here are the codes for each cartridge, to know which one you need:
-CB540A Black Toner
-CB541A Cyan Toner
-CB542A Yellow Toner
-CB543A Magenta Toner
Remember to always use genuine cartridges.
Dec 12, 2010 | HP LaserJet CM1312 All-In-One Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Recently changed the black toner cartridge in the Dell 3110cn printer. This past week when I print the entire page is being printed with a shade of gray. I think the toner cartridge has leaked toner and...
This could be a drum problem, the drum is part of the toner cartridge in this printer.
If the toner has leaked it will be all over the inside of the printer - you'll see it. I don't think that's the problem.
If the toner cartridge is an original Dell item, then it's likely to be replacable under warranty.
If the cartridge is a remanufactured item, it may be that the wrong toner has been used. Toner is NOT all the same, and this cartridge is one whe the wrong toner really will not work properly for long.
The chances are the changing the toner cartidge will cure the problem, provided you use an original Dell item, or a remanufactured item from a reputable manufacturer.
Apr 19, 2009 | Dell 3110cn Laser Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
May 18, 2008 | Epson AcuLaser C4000 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Xerox Phaser 6120/YN Laser Printer Logo
208 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
