Question about Kodak EASYSHARE M1063 Digital Camera
My Kodak Easyshare MD41 will not switch on
I have tried when it is on th echarger, but the charging light doesn't shine. There is no response at all.
    Genius:
  • Kodak Master
  • 1,099 Answers
In order to charge the batteries in the charger in most cases it requires KODAK rechargeble batteries.
Also clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
Posted on Feb 09, 2010
  • Dave  C
    Dave C Sep 25, 2011
    Just bought this camera, new, really cheap old stock, and it wouldn't charge. Turns out the battery hold-in catch is really bad, kind of has two position - partially in, and all the way in. Make sure the battery is facing the correct way by looking in and making sure the contacts line up and also by pushing it all the way down so the catch comes completely over the end of the battery.
My kodak easyshare MD41 has had charging issues since I bought it.. The USB cable that came with the camera won't fit right into the camera's port. I really had to push to get it in. Well, now it...
You will just need to buy a new cable.
Something like this:
http://www.amazon.com/Kodak-EasyShare-MD41-USB-Cable/dp/B003HMVF70
Hope this helps! Good luck!
Jul 27, 2011 | Kodak EasyShare MD41 Digital Camera
We were filming using the video camera mode on the Kodak EasyShare MD41 and it froze half way through the video when we played it back. Now it has completely frozen and the power button wont work. None of...
Here is an online manual for your camera:
http://support.en.kodak.com/app/answers/detail/a_id/19200/~/kodak-easyshare-md41-digital-camera%E2%A0%E2%80%94%E2%A0extended-user-guide/selected/true
You camera does have a battery and it is possible it simply needs to be recharged.
Jul 26, 2011 | Cameras
Kodak easyshare digital camera MD41, lens extends and closes when start button is pressed with fully charged battery light blinks red and turns off camera
hi open the battary comparment, remove the battery and check to see if there is a small button like thing (looks something like a small horn) there if yes then, press and hold it for roughly 20 secs and release reinsert battery and try powering on this would reset the camera to original factory settings at a hardware level
(i got my other Kodak c340 to work this way)
hope this helps
cheers
May 05, 2011 | Kodak EasyShare MD41 Digital Camera
The camera won't turn on, the lens comes out and then back in and the camera turns off. This is a Kodak Easy Share MD41. It's only been used a few times around the home to test it out so it's not been...
The problem is in the systems control board, it is defective or it has detected a problem in the camera. The issue could be the batteries not holding a charge sufficient enough for the camera to run causing it to shutdown. Since the camera has been used so little there must be warranty remaining on the item, it should be returned for quick check where it was bought to get the matter rectified.
Jan 15, 2011 | Kodak EasyShare MD41 Digital Camera
Kodak MD41 camera will turn off immediately after I turn it on. Battery is charged.
go to kodak.com they will assist you in each and every step.......they are awesome try it......
Jul 19, 2010 | Kodak EasyShare MD41 Digital Camera
I have a kodak easy share MD41. It wont come on
that is the most problem of kodak battery once you leave the battery inside of your camer awithout using for a long time. the battery life become less or easily damage.
Jul 08, 2010 | Kodak EASYSHARE M1063 Digital Camera
Kodak MD41 switching off as soon as switched on
I understand that you have checked the batteries and the cleaned the contacts. Eventhough here are the steps: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 2. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Nov 17, 2009 | Kodak EasyShare C315 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
1,632 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
