Question about StarTech.com StarView SV211K 2-port KVM Switch
Ford galaxy rear driver side window stuck down
    Problem Solver:
  • 18 Answers
This is most likely due to a switch failure (if your lucky, if not then a broken wire harness, or physically jammed window) the easy way to test is to remove the switch assy, and manually jump the contacts, if the windows moves, then its the switch assy, if not, then a much more intensive trouble shooting method is needed,
If your handy with a volt meter, you can do it yoruself, if not, then its diffacult enough that you should take it to a shop
Posted on Feb 08, 2010
My window on my 03 Grand Cherokee driver side rear is stuck down and will not go up all the other windows work fine from driver side controlexcept the rear window on the driver side now it is stuck down...
You will have to remove the door panel
Most likely you have a broken window regulator
& are not going to get it up
If it is a switch problem,only,then you unplug the
motor & put battery voltage direct from the battery,
to get it up, until you have time to work on the problem
Dec 02, 2014 | 2003 Jeep Grand Cherokee
Drivers window switch doesnt work
It's most likely a bad switch. Check it with a voltmeter or continuity tester to see if it needs replaced.
Mar 25, 2014 | 2005 Ford Galaxy
Ford alarm troubleshooting
If more than one light on the same side do not work, check grounds in the rear, most of the time the left and right sides use different grounding points. As for the Body control module, i doubt the problem is there, as there would probably more than just that going wrong if it was faulty. The BCM (body control module) is usually located under front seats, or hidden in the dash somewhere. I would like to be more precise on location, but we don't have ford galaxys in my country. Well... not any 2007 galaxys anyway, only 1970s and older. :P
Dec 31, 2013 | Cars & Trucks
Rear windows won't go down
This sounds like a stuck switch,try to unplug the switch (drivers side window) first and it should cure your problem.Let me know if this does it,,if not i will help you solve this issue
Jan 02, 2012 | 2004 Lexus ES 330
Right rear window will not go up or down from either the door button or the drivers door button and it is stuck halfway down ...
you have to take apart the side panel to see inside and you will find out that some of the parts got off the track of the window. If you do not know how to do this have someone who does.
May 24, 2011 | 1999 Ford Expedition
2002 Ford Explorer, rear driver side door
Wil it work at the door switch or not at either switch? If not make sure you have power and ground to the motor in up and down positions. if so suspect the motor.Also the cable operated regulators break and will not let the window go up or down
Jul 30, 2009 | 2002 Ford Explorer
2003 Ford Taurus SEL Rear Window Wont come down
if window wont work with either switch the 1 on the drivers main switch or the one on rear door it may just be stuck on weather stripping and may need help down with door open have someone press switch and w/ door open put hand on inside and out of glass pushing down if it starts working agian spray weather strip with silicone spray if it does not work need to test motor to see if its getting batt voltage if not its switch if it is u need new motor
Mar 28, 2009 | 2003 Ford Taurus
Window stuck down on 1994 ford explorer
while holding the switch in the up position, bang on the middle part of the door panel, if the motor is stuck then this will usually unstick it. but if motor is running then you will need a new window regulator.
Jan 06, 2009 | 1994 Ford Explorer Limited
Drivers side power window dosen't work,is all the way down and won't come back up
BTW, the window seems to only get stuck down if it is taken all the way down - I've never gotten it stuck partway down. So in the summertime I try to remember not to take the driver's side window down completely, just keep it an inch or so up.
Jul 26, 2008 | Ford Explorer Cars & Trucks
StarTech.com StarView SV211K 2-port KVM Switch Logo
103 people viewed this question
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
