Question about Panasonic PT-43LC14 43" Rear Projection HDTV
LAMP REPLACEMENT WHICH PANEL ON BACK OF SET HAS TO BE REMOVED FOR PROJECTION LAMP. PT-43LC14. THANK YOU. BRAD
    Genius:
  • 1,030 Answers
Lamp replacement on this set is through the front of the unit... the bottom front panel is removed to acess the lamp door. Place your fingertips under the front cover and pull it from the display. there will be a lamp cover door with a screw to remove. then you will have to loosen the screws in the lamp and pull the lamp out
Posted on Feb 22, 2008
Reset lamp timer panasonic tv
PT-43LC14/PT-50LC14/PT-60LC14.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here: http://www.dlplampguide.com/tyla1000.html
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Resetting the lamp timer for my Panasonic
You need the original remote to reset the lamp. Try to find a neighbor with a similar tv or buy one off ebay.
Mar 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Pt-43lc14
To reset the Lamp timer back to zero
simultaneously press the "down split channel" button on the bottom of the remote and the down volume on the TV for 5 seconds or more. You will get a message on the screen that the time has been reset to zero.
May 22, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Can't remove screw on lamp cover panel PT-43LC14
Using a phillips head screw driver, you need to grip the unit with your left hand and then push really hard against the screw head before starting to turn the screw. They are very tight from the factory. Once it breaks loose and starts to unscrew, the rest is easy.
Feb 27, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Tv won't turn on
I did a 2nd replacement with an original Panasonic TY-LA1000 Lamp, now my TV works just llike new.
Dec 17, 2008 | Panasonic PT-43LC14 43" Rear Projection...
TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Dec 11, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Lamp replacement
It is located in the front, down at the panel. Remove it and you will see it.
Jul 24, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Air Filter Waring for Panasonic PT-43LC14
This may be a temperature issue there is a thermal sensor that tell the tv its to hot and need air so it think its filte is cloged. make sure there is plenty of clearance for air flow.. however there may be more involved problem with the set ... the sensor could be failing
Nov 22, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
130 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
