Question about Kenwood Audio Players & Recorders
I have a Kenwood KAF-3030R, no sound output
I have a Kenwood KAF-3030R, went to switch it on the other day and no sound will come out, was working the day before. Checked everything I know
4 Suggested Answers
  • 63 Answers
SOURCE: just stopped working
please check if the supply is still present in your amp using a multimeter. if you dont have a multimeter, check the fuse that supply the amp. a broken fuse will not turn the amp. let us know.
Posted on Apr 15, 2009
SOURCE: kenwood
In the manual in the troubleshooting sections it describes how to set the preout mode and that fixed my problem even after I had disconnected my battery.
Posted on Aug 01, 2010
  • 15 Answers
SOURCE: My Kenwood KVT-516 has no sound, everything else
Check to see if you have a speakers A button and a speakers B button. Cycle them both on and off one at a time with something playing. This may turn the speakers back on. In addition you can check to see if you have a second room speakers feature that somehow got turned on- if so turn it off and the sound should come back. In addition you should download the manual and search for these features to show you have to deal with them.
Posted on Sep 16, 2014
Sherwood ax 3030r
What is the question? More information is needed before somebody can help you. What type of watts are you asking, power input, output, music, RMS, etc.
May 14, 2014 | Audio Players & Recorders
Kenwood CD player
Most car audio devices (like head units and amps) require a REM (remote) line to be connected to a switched power connection. This switched power is on when the car key is set to ON or Accessories.
Not knowing what Sony unit you had, I can't be sure, but it is likely your Sony had higher voltage preamp outputs than the Kenwood, as the KDC315 has 2V outputs.
Jun 30, 2017 | Car Audio & Video
Kenwood amp sound goes on one channel
You will need to check on the failed channel with reference from the working channel. If the model is having an IC check for the fusible resistors in the biasing circuit. If not your output IC could be faulty.
Open the set and check for any loose connections. make sure your speaker is fine and cross check for confirmation.If the speakers , the fuses are intact, then you will need to signal test to see if the premap is working or the output is at fault. So check this out. Good day
Jul 24, 2010 | Kenwood Audio Players & Recorders
Kenwood mixer shorted and requires repair
sounds like aproblem with the brushes are worn out or damaged armature if you contiue to use it before you check the brushes you will permetly damage it
Oct 07, 2009 | Kenwood KM800 Major Classic Stand Mixer
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
No sound output
hiya
have you checked the thermal fuses inside... they may of blown replacing the fuse may sort this out
Feb 26, 2009 | Audio Players & Recorders
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
My Kenwood KAC 9152D 1800W AMP acting funny
Sounds like you got the wrong speaker load by either parralleling some speakers or else you bridged the outputs in such a way to create the wrong speaker load or maybe all of the above. In short, it sounds like you have blown at least one of your output channels and its time for a trip to the repair shop. I suggest you disable your amp at once so that it doesn't do any more damage to itself.
Jan 09, 2007 | Kenwood KAC-9152D Car Audio Amplifier
190 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
