Question about Kenmore Dishwashers
Our model 587.1440 Kenmore dishwasher will not take in water. It willexpel water tho--what do you think the problem is?
SOURCE: My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Posted on Nov 25, 2006
SOURCE: Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Posted on Nov 01, 2007
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
bigg t
  • 640 Answers
SOURCE: New Kenmore Dishwasher Model 587-1401 has a toxic smell
Use a descaling agent.Clr (calcium,lime,rust) remover availiable at super markets,drugstores.Pour a cup in and run a couple of cycles.When finished keep the door open to air dry.
Posted on Apr 11, 2009
SOURCE: water does not pump into dishwasher from line, tho
the start buttom lights geen for 7 times , may be from the lack of water , but the water supply was solved & the dishwasher didnt start again !!!
Posted on Feb 01, 2010
I have a Kenmore portable dishwasher. The sink connector(not the adapter, but the white connector that has hoses attached) spits water out of the bottom during it's entire cycle. I have used other portable...
I think that the valve assembly in the end of your attachment hose is having problems, check with Kenmore and see if a replacement one is available and if your dishwasher is new enough perhaps it might be under warranty?
May 31, 2014 | Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Purchased 2007, Kenmore UltraWash d.w. makes loud buzzing noise that stats about a minute after 'start' and continues most of the time throughout cycle. Think it's the pump? Can't easily get it to be...
Please provide model number of the kenmore dishwasher.
Is there water in the base when the wash is complete? There could be couple of pumps in some Kenmore dishwashers - so hard to know which one until model number is known.
Dec 06, 2010 | Kenmore Dishwashers
My Kenmore elite dishwasher 665.13793K600 has 2 problems: 1. won't drain water 2. won't even start working today Please help!
I have a Kenmore model # 665.13793K600 and it has been having a small puddle of water remaining in the bottom at the end of each cycle. I've taken it apart and cleaned it. I'm thinking I may have the drain hose incorrectly positioned or it could even be something unrelated. I can only think of the drain because I replaced the kitchen faucets a coupe of months ago and it could be since then that this has been happening.
Sep 09, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Water does not pump into dishwasher from line, tho
Feb 01, 2010 | GE Dishwashers
Dishwasher leaks during the wash and rinse cycles from the front
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Apr 04, 2009 | Kenmore Dishwashers
Dishwasher does not want to drain
good thinking,first it would help if i knew the model # if you open the door it should be right there on the left side.has it ever drained for you? is there a new garbage disposer installed in the sink? the special screw is a torx.
Nov 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
186 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
