Question about Laguna Waterfall and Filter Pumps 2000
Pump does not restart after being unplugged for 20 hours. Checked and there is power supply,
  • 677 Answers
Pump has lost prime. Please check filters and screens, and then please let me know.
Posted on Feb 08, 2010
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
MY SYSTEM IS BEING RESTART AGAIN AND AGAIN. SO, PLEASE TELL ME. WHAT'S THE PROBLEM.
about three years ago i built a computer it was mxtx 24 pin board and i had a atx20 pin power supply i bought an adapter to convert the atx ps to a matx 24 pin and had this problem the cpu kept restarting after hours of problem shooting i narrowed it down to the power supply i went out and bought a 24 pin ps instaed of trying to convert 20 to 24 problem was solverd what im trying to say is check your power supply disconnect from board and reseat it see if that helps or try another power supply
Aug 28, 2010 | Intel D945GCCR Motherboard
No display after restart
bro I am having the same problem!! after searching I found that the pc gets display on my case if I remove power cord and press the power button (and holds on) of pc like 30 seconds and then reconnect the power cord and powers on!! this is how I get back display after restarting pc.
Feb 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
May 30, 2009 | HP Pavilion m7640n PC Desktop
1993 Ford E-350 Starts and runs for about 45 seconds then stalls and wont restart for hours. Put computer on it and get code 542 fuel pump secondary. I have new fuel pump and have checked and re attatched...
regulator most likely. Need to check fuel pressure both when running and after a stall. My guess is 20 lbs when it starts, 0 after it stalls. Replace that fuel filter also.
Apr 25, 2009 | 1993 Ford Club Extended
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Sep 04, 2007 | Compaq (480082-001)...
Laguna Waterfall and Filter Pumps 2000  Logo
123 people viewed this question
Top Laguna Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Laguna Garden Expert? Answer questions, earn points and help others
