Model TP2785C221 Ser#49970862 Phillip Magnavox On Sunday my T.V. began to have snow and no sound. I am connected to Dish Network. I spoke with a tech at Dish on Sunday and they had me check all cable conections and I ran a Diagnosis test on the T.V. They said it had to be the T.V. It will not go to AUX. and will only go to channel 2 and 99. Can you help me please. Thank you Tom McGuire raemcguire@bellsouth.net
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
First, you need to have the original working remote. You should be able to direct access any channel with it; ie: 03 should take you to channel three. The other thing you can try if the set has a MENU button is to locate autoprogram in the customer menu (make sure you have the set in Cable mode). Once engaged the set should scan all the channels with Dish hooked up to it. These sets have an unusual on screen menu--you may find just a list of items----scroll down to the bottom and keep scrolling down if you see this and it should give you up to 40 items. Even without the remote you should be able to access the entire customer menu with the front buttons and or change settings. Either you just need to reprogram or you have a serious problem with the set's microprocessor. This is a 27 inch set and if a micro problem it will be cheaper to replace it than repair. Let me know if you have questions and need more help---I am here to help. SD TECH
Posted on Feb 08, 2010
Ok my little sister has a magnavox tp2785c221 tv when she came home from school the tried turning on the television but never powered on when u press the on button u can hear a noise
It sounds that the line output transformer has damaged. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 01, 2012 | Televison & Video
Just got a 32 in. lcd / dvd combo from my dad its a '07 model - tda -03211c.....how do you hook up dish network's main unit to this tv?
We would be happy to help you get your TV hooked up to yourDISH Network receiver. Please visit the "How to connect receiver toTV" section of our website here: http://www.dishnetwork.com/SupportSection/setup-receiver-totvfor step by step instructions. Select the model receiver that you have; themodel number of the receiver can usually be found on the lower left corner ofthe receiver looking at it from the front. Please remember that we are here foryou 24/7 on our Customer Support line 1-800-333-DISH (3474). Thanks so much forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Mar 02, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Como puedo encontrar el codigo para mi televisor philips magnavox me podrias ayudar pls
Hola mi nombre es Kimberly Escobar con DISH Network y seria un placer ayudarle proveendole la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con su televisor marca Philips Magnavox son los siguientes: 566, 888, 560, 829 y el 656. El procedimiento a programarlos es el siguiente: Oprima el boton de T.V localizado en la parte de arriba en el control hasta que los demas botones a la par se iluminen en rojo, una vez esto seceda ingrese uno de los codigos seguido por el signo de numero, por ejemplo: 566#. El boton de T.V deberia iluminarce rojo 3 veces. Despues de esto puede intentar usar el control con T.V no le podemos asegurar que controle totalmente todas la funciones de la T.V. Este link tambien le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara codigos para sus aparatos y el procedimiento a como programarlos. Espero esto le ayude muchas gracias y si tiene alguna pregunta me puede contactar directamente a mi correo electronico kimberly.escobar@dishnetwork.com
Feb 28, 2011 | DISH Network IR Remote Control
I got a Magnavox tv model number 27ms343s from a friend,but it didnt have a remote.The tv is locked and wont turn on by the power button,how do i find a code to set it up with my dish network remote?
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your Magnavox television; here some of the codes we currently have: 560, 829, 566, 761, 891, 828, 656, and 770.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this help and thank you for being a valued DISH Network customer!
Phillip Chang
Feb 10, 2011 | Philips Magnavox 27MS343S 27" TV
How can i connect my tv to the dish and watch channels? i have dishnetwork
We would be happy to help you get your TV hooked up to yourDISH Network receiver. Please visit the "How to connect receiver toTV" section of our website here: http://www.dishnetwork.com/SupportSection/setup-receiver-totvfor step by step instructions. Select the model receiver that you have; themodel number of the receiver can usually be found on the lower left corner ofthe receiver looking at it from the front. We really hope this informationhelps you get everything connected, please remember that we are here for you24/7 on our Customer Support line 1-800-333-DISH (3474). Thanks so much forbeing a valued DISH Network customer!
Phillip Chang
Jan 23, 2011 | JVC AV-27230 27" TV
Just moved my TV to a home with cable. It was hooked up to Dish network. there is no signal. Thank you.
We would be happy to help get your DISH Network signal back.The first thing we want to check is if there is anything blocking the signal toyour satellite dish like tree branches, severe cloud cover, or snow build-up.If it is safe to do so, remove the obstruction or wait for it to pass. If thatis not the case then reset your receiver by unplugging it for 10 seconds thenplugging it back in, the reset may take up to 5 minutes to finish (note: thereceiver's power plug usually has a red tag attached to it). At this point wewant to check the connection between your receiver and the outlet; please visitthis link and select the model receiver you are using to check the wiring ofyour receiver: http://www.dishnetwork.com/SupportSection/setup-receiver-towall.Once you have check the connections perform a check switch test. Press the menubutton, then the numbers 6-1-1 on your DISH remote, this should take you to thepoint dish screen, select check switch on the right, then test on the bottom ofthe screen. Once the test is complete exit the menus and let the receiveracquire the signal (If Error 836 appears, do not save the matrix, cancelit and call our 24/7 customer support number listed below.). After all thesesteps if the receiver is still not getting the signal it should please give usa call on our 24/7 customer service line 1-800-333-DISH (3474) for additionaltroubleshooting.
We hope this gets your signal back. Thanks for choosing DISH Network!
Phillip Chang
Nov 12, 2010 | Olevia 742I 42 in. LCD TV
Dishnetwork remote , what do i push before entering codes for magnavox
We would be happy to help you with getting your DISH Networkremote to control your Magnavox TV. Press and hold the TV button located on the top ofyour remote until all mode button back lights come on, then release. Usethe number buttons to enter the codes for your Magnavox TV. Press the pound (#)button to save the code in the remote. To check that the code works try several different functions on theremote to make sure it will properly operate the TV. Remember that some codesmay not be compatible with your equipment. If this is the case, try the othercodes listed for that device until you find one that is compatible with yourequipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
Oct 20, 2010 | One For All URC-3021 Remote Control
I need the remote code can't find it i have a dish network universal any help would be appreciated.
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Philips Magnavox DVD Recorder: 801, 766, 556, and 585.
Press and hold the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Philips Magnavox DVD Recorder, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your Philips Magnavox DVD Recorder. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, try the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
Oct 01, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
