Question about Telex M-560 Consumer Microphone
Telex M-560 I am able to get the mic to work but the volume is very low I am wondering if there is a driver I need to download as this is a newer computer than the original I purchased it for.
  • 4 Answers
May be mic preamp is not working correctely. condenser microphone voltage is very low or mic is fault . check your microphone cable . preamplifer of condenser mic may be leaking .check ur mic driver and audio .
Posted on Feb 22, 2008
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
Telex ht200 is fatter microphone and I am looking for a microphone clip to mount it on a microphone stand. Universal clips are too skinny - they will not fit around the mic. Does anyone know where I cn get...
Here you go. I would use something like this. This has a 1.75" (44mm) diameter. http://www.bhphotovideo.com/c/product/298898-REG/WindTech_MC_4_MC4_Extra_Large_Heavy_Duty_Microphone.html
You can also go here http://www.crossroadsaudio.com/Rentals%20Catalog.pdf scroll down to page 5 and you can use this - $15.00 Telex ELM-22S Black Lapel Mic, Shure TA4F w/ Mic Clip -- That clip is the same diameter as your mic and is made by Telex.
Mar 22, 2011 | Telex HT-200 Handheld Microphone...
I have a logitech webcam but its older and i have a newer computer so everytime i hook it to the usb port the computer tells me it cant detect it so what can i do, upgrade something?
The driver for the camera need to be installed first.Look for the driver in the Logitech web site support and you can download a newer version of the driver which will be better for the web cam.Newer web cam models nowadays are cheaper and has better video and higher megapixels which work even in low light situations,why don't you get one.I got a gigaware which has a mic and a motion detector at a low price.
Dec 04, 2010 | Logitech Webcam
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
Compaq C773:Internal Mic very low voice,External Mic not detecte
1. click on the start button on the windows screen
2. program, then accessories, then Entertainment, then volume controller
3. select option,then properties
4. select mic check box to activate your mix option in the volume controller then ok
5. you can increase your mike volume and you can put it on mute option etc..
try this, hope this will help you out.
Jun 19, 2009 | Compaq Presario 700 470024-192 Notebook
Side A led volume indicator is low when duplicating tapes
This is not a PrintWise burner problem. I posted incorretly. Henry
Jan 29, 2009 | Telex PrintWise 2000i (2000I) Burner
Telex WT55 wireless lapel mic & FRM70 Receiver
How do I set the squelch on a TELEX FMR-70 receiver?
Jan 27, 2009 | Telex FMR70 VHF Wireless Microphone...
Telex prostar wireless mic.  leads came off of mic element.  One green wire and one black.  Which one connects to center of element and which connects to rim.
Hi..
The rim is "ground" or the (-) side of the mic.
Find out which wire goes to ground or a (-) on a battery.
Solder that one back to the rim
Dec 11, 2008 | Telex FMR-200H Professional Microphone
Using built-in Telex mic?
There should be microphone cable that plugs in the back of the monitor to the back of the pc microphone jack. It's color coded PINK.
Jun 13, 2007 | Compaq fs740 17" CRT Monitor
Telex M-560 Consumer Microphone Logo
538 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
