Question about Samsung SyncMaster 932B LCD Monitor
Syncmaster 932B need instructions to open the display to check the backlight.
  • 5 Answers
Lay the monitor face down on a padded horizontal surface. I use a thick towel on a table, Remove the pedestal by unscrewing the wing-screw on the bottom. This will allow better access to the slots in the case halves on the bottom of the monitor. Use a screwdriver about the size of the slot, insert and twist. The case should separate with a loud snap. Do this for both slots. Then, using two screwdrivers, one to twist and unsnap and one to hold the gap open, work you way around the edge until you are able to pull the two halves of the case apart. You may want to pad the twisting screwdriver with some tape around the blade. The corners are good places to work since the case is stronger there. Note that the circuit board chassis is not attached to the LCD panel, but is held in place by tabs on the inside of the rear case half. Keep this in mind when you reinstall the case back.
Posted on Jun 02, 2010
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
My samsung syncmaster 932b is blurry. There is a shadow slightly to the right of each object on the screen. How do I fix this?
cmwag, Try some isolation testing. Will 932b do same thing when connected to a different KNOWN GOOD pc? Will your pc display a sharp, bright, crisp, colorful screen when connected to a KNOWN GOOD monitor? Is the VIDEO card seated properly into its connector on the motherboard? Is VGA connector clean and tight into the port on back of pc? Hope this was of some use. 12fixlouie
Jan 29, 2010 | Samsung Computers & Internet
Monitor takes long time to on
GuyInTrouble, If you see an increase in time, 4-6 min> 8-10min could be oxidation build-up on an already "thermally intermittant solder connection. 12fixlouie
Dec 17, 2009 | Samsung SyncMaster 932B LCD Monitor
I have a samsung syncmaster 932B, it worked fine, then when i turned it on it turns on and after a second it turns back off, then i noticed that it shows but its very very dark, i saw some colors but still...
If you look very closely at the screen with the computer on, you may be able to see the desktop etc. but very dark. If this is so, then the blacklight is not working most probably caused but the inverter failing. This can be repaired but is best left to a professional.
If you wanted to fix it this yourself then Google for the inverter data and instructions on how to open the monitors case etc.
Nov 01, 2009 | Samsung SyncMaster 932B LCD Monitor
When the monitor is turned on it displays "analog, digital" then "check signal cable", what is the problem?
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Sep 11, 2009 | Samsung SyncMaster 932B LCD Monitor
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung SyncMaster 932B LCD Monitor Logo
1,129 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
