posted by InGear on Feb 22, 2008
I have a Maytag dishwasher that's not cleaning well.
My guess is that the spray rms need to be cleaned,. I saw some clogged hole, but can't figure out how to remove the arm.
I can see that the sides unclasp, but that's it.
Thanks
Comment by InGear, posted on Feb 23, 2008
I can't find a thumbscrew. The metal sleeves are fastened by two tabs on each side. I removed one but there is nothing there.
Comment by InGear, posted on Feb 24, 2008
I located it. It's the top plastic piece thatlooks like a doughnot.
Thanks for your help.
Best Solution
metal sleeves at the end of the lower spray arm?? dont remove them they only protect from hitting against heate and melting. should be a center thumbscrew in spray arm loosen that nut and should come right out, pokin with wire or toothpik willwill clear joles but you gotta remoe the debris from the arm other wise first run will shoot right back nto holes
Comment by aborcass, posted on Feb 24, 2008
what's model number on unit id like to see exactly what were dealin with
Rating Locked! (?) InGear has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Jet Tech Systems STEALTH Dishwasher
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Kenmore dishwasher spray arm...
Kenmore model 665.158999100 I... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
