Question about Radio Shack Pro-83 Scanner
How do I do a master reset on the pro 83 scanner
    President:
  • 2,761 Answers
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Posted on Feb 08, 2010
2 Suggested Answers
SOURCE: hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
Posted on May 31, 2009
How do i reset radio shack pro 83 scanner back to factory settings
With the scanner off, press and hold the 2, 9, and HOLD keys. While still holding them down, power on the scanner. Continue to hold the 2, 9, and HOLD keys until the display says CLEAR.
May 04, 2014 | Radio Shack Pro-83 Scanner
THE WORD WIRED IS ON SCREAN
WIRED should only appear on the screen if you have a programming interface cable connected to the scanner. Assuming that you do not have the cable connected, you'll need to RESET the scanner to clear it and restore it to normal operation. This process will erase/delete everything that you've programmed into the scanner, so be prepared to reprogram it. To RESET the PRO-83:
- Press and hold the 2, 9, and HOLD keys and power the scanner ON
- The word CLEAr will display to confirm the RESET
Need the manual for your scanner? You can download and print it, at no cost, here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 17, 2010 | Radio Shack Pro-83 Scanner
Locked on search
You may have inadvertently locked the keyboard. If a key-shaped icon is showing on the display, press and hold the FUNC and KEYLOCK keys until the icon disappears. If that doesn't work, you may need to reset the scanner to restore normal operation. NOTE: this operation will delete all information that you have programmed into the scanner. To RESET the PRO-83, power the scanner OFF. Press and hold the 2, 9 and HOLD keys, and power the scanner ON. After about three seconds, CLEAr should appear on the display to confirm the RESET.
Need the manual for your scanner? You can download and print it here:
Bill B
Jun 07, 2010 | Radio Shack Pro-83 Scanner
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 19, 2010 | Radio Shack Pro-84 Handheld Scanner
In my Pro-83 Bank, I am missing banks 2 and 8. How can I get these restored?
While the unit is scanning, just push the 2, and then the 8 and it toggles them on and off while in SCAN.
Jul 27, 2009 | Radio Shack Pro-83 Scanner
Hand held pro 83 scanner
May 30, 2009 | Radio Shack Pro-82 Scanner
PROGRAMING
Hi - You can download the manual from the link underlined in blue below:
Pro-83
See pages 24, 25:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 15, 2008 | Radio Shack Pro-83 Scanner
Program
Radio Shack has a manual for the PRO-83 scanner online in Pdf format. It worked great for me and I honsetly could not tell any difference in the PRO-83 and my PRO-84 !! It worked great for me and I had my scanner set up and working very quickly!! Hope this helps you all as much as it did me.. the manual is for the PRO-83 200 Channel compact scanner w/signal stalker search and lighted keypad.
Hopes this helps you all !!
Aug 21, 2007 | Radio Shack Pro-84 Handheld Scanner
Radio Shack Pro-83 Scanner Logo
462 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
