Question about Whirlpool Duet GHW9150P Front Load Washer
Will not complete wash cycle and gives the code F 20
  • 863 Answers
Whirlpoolwill not complete wash cycle and gives the - 2_bing.gif has really gone to sh.t over the years. Don't know why they can't spend more money on quality control. Maybe cause they used most of it to acquire Maytag.
Anyways, I digress. This F20 code says you got insufficient water supply.
Free things to try: Have the water company come out and check the water pressure, turn water valves all the way up, check the hoses to make sure they are not kinked, check the inlet water ports to make sure they are not clogged, don't install one of those stupid Watts Flood Safe hoses from Home Depot because they are total rubbish, and make sure your discharge hose has no sag in it and goes straight up and then bends into the discharge pipe.
Now if you want to pay for parts:
Water Valve Whirlpool part # 8540751 or get you a Flow Meter part # 10110225
If you don't want to deal with all this bullsh.t, then take the thing back for refund and get you a different brand.
Posted on Feb 08, 2010
What does F 20 error code mean?
There is not enough water entering the machine.
Oct 03, 2012 | Kenmore HE2 Plus Front Load Washer
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at macmarkus@live.ca and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
Does not complete wash cycle. Machine cuts off in the wash cycle with the water still in the tub. I can re-start at the beginning, but it just stops in the middle of the wash cycle and I cannot get it to...
You need a new pump. When the pump is bad it won't drain the tub. It just stops after the wash cycle. They aren't to much of a pain to replace. Repair man will be about $200. Do it yourself about $65. Give Sears a call and they will give you the run down. Good luck. If you are going to do it yourself let me know and depending on the model I could give you step by step RR. Good luck. Regards.
Oct 19, 2009 | Washing Machines
Code F-20 what does it mean?
“F20” on display
(Water Inlet Problem—no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Error Code F-20
I have same machine and manual says, "F20" on display (water inlet problem - no water or insufficient water supply). Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following. Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re select cycle and press START. if the problem remains, call for service.
May 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
