Question about Canon EOS 30D Digital Camera with 18-55mm Lens
Error 99 on 30D Canon
I have a canon 30D. I have error 99. I can take one picture then get the error. I take out battery, then replace, then can take one more picture then same error then repeat process. The manual says not compatable lens. I have the same problem no matter what brand lens on camera, even with Canon lens. Can you please help?
  • 1 more comment
  • mjurow Aug 27, 2008
    I also have the same problem, we are using the same lens we have used for a year and a half and nothing seems to precipate the error, then every once in a while i can shoot 10-15 before it occurs, but it seems that once it occurs, i will get it after every one or 2 shots!
  • O'Neil Oliver
    O'Neil Oliver Dec 17, 2008
    I was using the 17-85 lens for over a year now , however on the 30th. November 2008 outside was cold and the camera gave me a err99.
    I went back into the church and the camera worked with out any issues. Later that evening the church door was open and as I was shooting in the door way the camera gave the same error99. Ever since then this has been happening only with the 17-85lens. I have a 80-200 and a 35-80 these lenses I have NO issues with.
  • d56davies Dec 18, 2008
    EOS30D with 17-85 lense
    Never any problems until 2 days ago.
    Error 99 and the need to switch on/off or remove battery.
    Leadup was taking low light photos in the cold and foggy early morning.
    Since then intermittent, but consistently low light/outdoors.
  • 51 Answers
Had this problem before and i found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
  • 153 Answers
if it still takes a picture (even if its black) its most likely a faulty shutter.
unfortunately error 99 can be many things. If you can remember what lead up to it i could possibly be more precise, but its most likely going to need a service center unless you fancy stripping the camera down
Best of luck
Posted on Jun 04, 2008
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
New canon t2i. keep getting error 70. haven't even been able to take a single picture
hello. good day. error 70 is appears when malfunctions related to images have been detected.
try doing the following:
1. power down camera and remove battery
2. power down HDMI device or powered adapter
3. unplug the HDMI from the body, then plug it back in
4. power up HDMI device or powered adapter
5. insert battery and power up camera
hope this helps. is error still appear. try this link for canon support
Apr 29, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 14, 2009 | Canon Cameras
Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
May 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99! Wont' take picture, the message states
Go to the website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
S400 memory card error. Turn on camera - display "NO IMAGE MEMORY CARD ERROR". Can not take pictures, can not display pictures. Have several memory cards - same message, different cards. If the camera...
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
Feb 21, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Canon eos 40D error 99
Check this link:
Oct 20, 2008 | Canon EOS 40D Digital Camera
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon error codes
I have a 100-300mm Quantaray lense and have the exact same issue. I spoke to Canon about this and they suggested cleaning the contacts. That helps for 1 picture. You would have to remove the lense and rub the contacts between each picture. Not a good plan. They suggested the Quantaray may have a fix or repair for the lense and to contact them. However they have no listed 800 number nor any website. only other suggestion is to contact a camera shop and see if they can service the lense. Only other option is to replace it.
Apr 22, 2007 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Canon EOS 30D Digital Camera with 18-55mm Lens Logo
1,175 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
