Question about Music
The pedal keys doesn't work, no sound coming out of the upper notes of the pedel keys.
  • Music Master
  • 5,603 Answers
We can only guess at what type, model, and brand of instrument you have.
This is probably some type of organ... however there are many types.
IF the pedals are part of the main body of the organ, I would suspect a broken wire.
If it is a console organ, often the pedals have tabs that actuate switches. Often people place thess on a rug which CAN block the pedal from moving far enough.
Another thing is that SOME voices that can be used by the pedals on some organs do NOT span all the pedals because the instrument being emulated won't go that high in pitch.
Posted on Feb 08, 2010
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
My casio privia px830 pedal doesn't sustain enough,
It could be that the electronics of the pedal are dirty, or that dirt has collected under it causing it to not depress all the way. Try taking it apart and cleaning it with a Q-tip and rubbing alcohol. Be very careful of any wires or delicate articles.
Dec 06, 2011 | Casio PX-830 BK Privia
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Our Yamaha YDP223 has an issue with the damper pedal. When it is depressed, the notes (F#, G) in the upper ranges make a high pitched, annoying sound as the note dies away. We were dealing with this sound...
All sound is generated digitally and the pedal doesn't modify the sound, it just sustains the generator. This is a strange problem and best suggestion iis to find another unit and compare... it may be a characteristic of the design. There isn't anything that you can do to change this. It could be there is a bad ground inside the unit or the digital data is corrupt in the processor. The fact that it is on a particular set of notes is strange...I just checked on my Yamaha piano that is essentially the same electronics and I notice that on one octave above the middle when one strikes F# and G they "ring out". Now this MIGHT be due to the characteristics of the speakers. Those particular notes seem to clash more. I don't have other speakers on mine and unfortunately you did not mention what brand model you have attached. Consumer grade speakers like fancy stereo speakers do NOT do well on these instruments. One has touse pro grade speakers AND use proper interconnecting cables. The speakers, powered type, must be powered from the SAME receptacle as the piano to avoid ground loops.
Feb 20, 2011 | Yamaha YDP223 Digital Piano
My Yamaha electronic bass pedel is not working. If I unplug the connection to the computer and plug it back in I will hear only 1 sound of the base drum. Could the base pedel round pad which is hit by the...
There is a piezo sensor behind the pad typically. This can be dislodged or damaged. FIRST check your cables and try plugging the bass into another inout and see if it will trigger that sound. If not, you will need to repair the bass pedal.
SOME pedals have a sensitivity control which is a tiny pot accessable through a hole... this too is easily damaged if wrong type screwdriver is used to adjust it.
be sure and check for a broken cable, especially near the ends.
Sep 22, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
A really bad 'off key' note
what is make and model? I have owned several keyboards, with 2 of them Korgs in which I would connect a damper pedal. I noticed that when I help down the pedal, after so too much input within the cpu of the keyboard, it would 'short-circuit' and sound like I had played an 'off-key'
If you have been using the damper pedal, and even if you release a little on up on it, but not all the way, the 'off-keys' will still sound. I must always make sure the pedal is placed in a position that my leverage action of my foot will completely 'release' the overtones still being processed by the keyboard (whether they're audible or not)
Jan 11, 2009 | Music
Music Logo
146 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
