Question about HP LaserJet 4700DN Printer
HP LaserJet 4700DN Duplexer Jams
This machine has constant jams at the duplexer. it will send the second sheet into the duplex unit before it retracts the first one fed into it.
any known issues?
  • Troy Scott
    Troy Scott May 11, 2010
    is it giving an error number? Does this printer have a duplex tray that can be removed or is it duplex internally?
  • Anonymous Mar 28, 2014
    The Duplex Feature Will Not Turn On In This Brand New Machine
    Genius:
  • 3,587 Answers
Hmmm..check the paper for riffling(with fingers before placing in tray)..and the rollers can get slippery, after a period of time...
check your computer warranty for FREE here
Posted on Feb 22, 2008
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
Duplexer problem
There are several thing which may cause unexpected jams in the duplex tray...,
1. first thing to do is eliminate all other possibilities by removing the netCard/Net connection Parralel connection so the machine is Stand Alone. make sure there is paper in the feed cassette 2 ( paper Tray)
press the TICK to enter menu
scroll down to diagnostic- press TICK
scroll down to paper path test - press Tick
scroll down to Source and select tray 2
scroll down to Duplex And select YES
( if the duplex option is not visible here then there is a connection/seating problem with the duplex tray)
Scroll down to copies and select 10
scroll up to print test page and press tick
the machine should now start duplexing 10 pages,
if you get the same error ( 1 page enters then jams)
it could be a dirty/snapped paper entry sensor,( looks like a little plastic match stick that protrudes into the feed path of the paper)
use a can of pressurised air to Blast any dust away from this arm and the surrounding area being careful to follow the Paper sensor Arm back to the sensor and blasting this as well-
Duplexer tray are cheaper than an engineer call out, if the fix above fails , your cheapest option may be a replacement Duplexer tray, available from most HP office equipment Stores as well as Belmonte Business Equipment.
Jul 23, 2013 | HP LaserJet 4250n Printer
It gives me a bad duplexer connection error, im not sure where a duplexer is located
The duplexer on this machine is mounted right on the top where the paper exits. It should have a clear paper guide on it. When duplexing,the paper comes out here, and then reenters the machine.I would try reseating the duplexer as I have had them dislodged by users sometimes when they are removing jams.
Jul 28, 2011 | HP LaserJet 4700 Printer
JAM IN DUPLEXER CONSTANT ON DUPLEX JOBS FINE OTHERWISE.I HAVE REPLACED DUPLEXER,ENGINE POWER BOARD,DCE CONTROLER,REVERSING ASSEMBLY,FUSER UNIT. ANY IDEAS.
You've done everything I would have done and more.
How about you installing a DOA duplexer. At this point I would change it again. Is there another printer that you can swap duplexers with?
There is a paper path sensor test (letter H) and manual sensor test . I don't know if the Component test checks the duplexer, but you should be able to find out.
Is the printer still under warranty? Can you call HP or are you an HP tech and you can call 2nd level support.
Just a thought....when you run a Config sheet, does it show the duplexer?
May 18, 2011 | HP LaserJet M4345 MultiFunction Printer
My HP4100 DTN is continually having paper jams for no obvious reason. What can I do to resolve this? (I mean, I know how to resolve the jams, but how can I make sure it does not jam all the time)
Old age printer, prepare to replace the parts.
Step 1: Clean all paper path sensor, replace paper pick up rollers, seperation pads, check with out duplexer unit..
Step 2: Even paper jamming replace fuser assembly..
Step 3: Check with duplexer unit, clean deolexer sensors & rollers..
Nov 23, 2010 | HP LaserJet 4100dtn Printer
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
Paper jams only while duplexing
Back door broken, diverter gate broken?
I would look for something like this. did the tech clean the duplexers tires??
I would also try a different duplexer if possible-paper path sensor may be dirty or obstructed
Mar 07, 2008 | HP LaserJet 4350 Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4700DN Printer Logo
586 people viewed this question
Seeker5211
Seeker5211
