Question about Makita BMR100 Radio
The external aerial wire has become detached from it's solder point, (still attached at the base of the aerial with the spade connecter) where should it be soldered back onto, on the PSB. Please advise?
  • 494 Answers
With no idea of what the radio looks like inside and there are literally thousands of radio designs, there would be no way of explaning the place to solder the wire. Can you send some jpgs of the chassis?
Posted on Feb 09, 2010
When removing snow on to pf car, aerial roof top antenna detached from base. wire still attached. How to fix?
Should be able to super glue it back down. I would use Gorilla Glue myself.
Dec 30, 2015 | Cars & Trucks
How do I repair detached incase wiring
Heating element connections r riveted together - u can't solder them as it would melt when running.
If the wire detached at the element it is near impossible to reattach it.
U would have to remove the rivet and replace it with the wires connected. My experience is that the mica that it is attached to is too fragile to get the ribvet removed.
Oct 06, 2014 | Welding Tools
Can i connect an external antenna to a sanyo awm 2000u stereo for better tuner reception?
Your stereo came with a piece of wire attached at the back. This is/was the FM aerial. It should be roughly 1 metre or approx 38" long. There is no socket on the back of this stereo to attach an external FM aerial. So if the wire broke off then you're going to have to either attach some new wire to the stub, or open the set up and solder directly to the circuit board.
The exact cable lengths for an FM antenna to pick up 88-108 MHz is 37.66" long.
Sep 12, 2014 | Audio Players & Recorders
I want to extend the aerial wire by 6m. I have attached co-ax plugs but the picture is breaking up.
Probably because there may be a bad solder joint or connection in one of the connectors. Did you solder these connectors on or is it a screw on type of connector? What you can do is to gently flex the cable at the connector and see if that makes the picture break up. If it does then that is your problem and you will need to solder them. By the way, it is no longer called an aerial but rather an antenna.
I have been a lisensed ham radio operator since 1958 and have soldered hundreds of connectors to cables. At that timewe used to call them aerials.
Good luck,
Marty
Jul 20, 2014 | Televison & Video
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
It pause temporarily at times during regular tv programming. What can the problem be?
I'm not quite sure what you mean by "pause", but if you mean the picture freezes or pixellates and the sound cuts outs then it's caused by a bad signal - know as "Digital Cliff Edge" - see attached image.
If you are using an aerial, check all your cables are connected properly and that your aerial is securely mounted, pointing in the right direction and none of the elements have become detached - particularly the dipole where the co-axial cable attaches.
If you are using a dish, again check all your cables are connected properly and that your dish is securely mounted. If the bolts are loose and you can move the dish by hand, then it's possible that your dish has moved from the correct alignment. You will ideally need a signal meter to correct this although it can be done by trial and error.
You should also note that dishes are susceptible to signal-loss during bad weather, particularly strong wind, heavy rain and snow. If you are only losing picture in bad weather, there isn't much you can do apart from making sure the dish is rigidly fixed.
If your aerial/dish is OK, try replacing your fly-leads (the short section from the wall socket to the TV) and/or the cable from the aerial/dish to your TV.
Hope this helps.
BElectric
Nov 05, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Won't heat
I have the same smoker with the same problem. I checked the heat element with an ohm meter, it was good so just cleaned the burnt residue from the male spade connectors attached to the element with a dremel tool. Slipped two new female spade connectors over the ones on the element and soldered them with the wires attached with a 1/16' silver bearing electronics solder. Now the connections cannot become loose and burn up again. I tested everything out and then wrapped the exposed connectores with non conductive fiberglass electrical tape and covered everything with expanding foam that comes in a spray can. Easy fix for me after reading all the posts from you guys here. Good luck and go for it! All I had to buy was the foam insulation.
Gary
Corpus Christi TX
Jul 13, 2008 | Masterbuilt ESQ30B Smoker
Wiring
I'm no expert but currently have the lid off my machine. Roughly where did you find the disconnected wire? I assume as you replaced the belt, it is at the back of the machine? There are a couple of male spade connections just above the water pipe inlets where I can see a brown and white wire? Does your wire have a female spade connection?
May 14, 2008 | Hotpoint Ultima WD72 Front Load...
Makita BMR100 Radio Logo
157 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
