Mixer 1622fxuli l bought power speakers to hook mixer up with on back do l need 4 cables going into mixer for speaker because on skeakers there are 2 plug ins l quessing the one plug is for mics on the back of speakers but l was told l needed 2 cables for each speaker but on the board there is no room for 4 cables to run the speakers l am kinda confussed thanks
  • 206 Answers
The two plugs are what is called Daisy chained this means they are both the same. This is so you can simply hook the speaker to the amp, then from the other plug hook another speaker, then from that speaker hook another speaker, ect...
Posted on Feb 22, 2008
I'm a guitar player, never had to mess with the PA system. I needed to come up with a monitor system to work with a non powered mixer used for powered mains. I can't afford good powered speakers, so I...
This mixer will run 2 8 ohm cabinets per side, if this is an older unit, it has only one NL2/combo jack per channel....with the button on the front panel in the Main Monitor position you can run 2 main cabinets and 2 monitor cabinets, you will have to daisy chain your speakers.All speakers powered from the back of the unit must be passive, no powered speakers.....if you want to use this head just to run moitors and run a pair of powered mains then connect the jack on the front that says main out to input of your powered speakers, hopefully your powered speakers can be daisy chained at low level, then if you want to use the 8600 to power only monitors, get a 1/4 in y cable and plug it into monitor out on the front of the mixer and then plug it into PA 1 and PA 2 to the right there and both sides will now be the monitor mix from this mixer and it will run 2 speakers per side, as long as the cabinets are 8 ohms.
Oct 09, 2013 | Peavey XR Series XR8600 Powered Mixer
Powering a passive stage monitor
A passive loudspeaker requires an amplifier to increase the power from the mixer.
An active speaker does not require an amplifier and will work direct from a mixer as the amplifier is built into the speaker box.
Jan 20, 2018 | Behringer Pmp3000 16 Channel Audio Mixer
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How to in install the speakers to it
You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
Dec 29, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Bought a powered monitor as it said to do even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked it up to monitor...
You didn't mention what brand powered mixer you have, HOWEVER MOST powered mixers also have a line level monitor and main output jacks. These are almost always 1/4 inch jacks. In any case you should be using BALANCED lines to the powered speakers using either XLR or TRS connectors on the ends. Please tell us what powered mixer you have so we can give you better answer regarding which connections to use. IF for some reason your mixer does NOT have line level outputs, you can use a high level Direct Box to condition the powered outputs to be sent to the powered speakers..
Also make sure ALL your interconnected equipment is powered by the same receptacle or source to avoid damaging due to ground bounce on utility lines and circuits. This often means running an extension cord from the stage where the powered speakers are along with a snake of the audio cables.
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
I have Berhinger 1680s powered mixer I have 2 Mackie 350 V powered speakers Can I hook them up? How do I?
Thought I answered this. Using balanced TRS cables, connect the powered speakers to the Main L and R 1/4 inch jacks on the top of the unit.
Nov 27, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Can I hook up 2 separate power amps to PMP3000? I
Better way... Connect the main speakers via the Speakons and then put a Power Subwoofer to one of the Monitor connections IF you are not using both stage monitors. If you need to kill the lows to the mains, use the EQ in the PMP-3000.
Use the EQ that is USUALLY on the subwoofer to kill the highs to the sub.
Lot less cables and hardware.
REMEMBER for equipment safety, power ALL interconnected equipment from the same source be it a receptacle or power distribution system.
Powering parts of a system from receptacles strewn around a room is asking for trouble of ground loops and ground faults.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
99 people viewed this question
