Question about LG 42LC2D 42 in. LCD HDTV
Pc to tv
Iv pluged my pc in to my lg tv using rgb pc plug but the tv says theres no signal
22" LG - it says no signal with a PC input, i have changed the input label to PC and still no luck
    New Friend:
  • 60 Answers
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Posted on Feb 22, 2008
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
TRYING TO INPUT LAPTOP TO RGB IN,AUDIO WORKS BUT VISUALY "NO SIGNAL"
Reading the online manual - You should have the laptop connected by VGA - PC input
VGA Connection you need to select the correct input on the TV
  • Select the RGB-PC input source on the TV using the INPUT button on the remote control.
you will need to set the laptop up to output to the VGA output, to do this - varies by different manufacturers - But often F4 or F5, with the FN key selects the VGA output - have a look at the F keys across the top of the machine and see if you can see a picture of a screen - then use the FN and that F key together to toggle between display it will change to <Laptop Screen Only><Laptop screen and VGA output><VGA output only> not necessarily in that order.
This is the support site for that TV http://www.lg.com/us/support/product/support-product.jsp
direct link to the PDF user manual http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=37LG30&matchedModelCode=1000003995&searchEngineModelCode=37LG30&initialTab=documents&targetPage=support-product-profile#
Mar 31, 2010 | LG 37LG30 37 in. LCD HDTV
I want to connect my laptop to my lg tv. i have the RGB cable but it is showing no signal on the tv, why?
You need to tell your laptop to send the video signal to your rgb output interface by using your function keys. Usually Fn+F2 or F8.
Mar 21, 2010 | Computers & Internet
What type of audio jack rgb/dvi in on rear of lg 50ps3
the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
so LG diagram shows separate audio into Audio in RGB/DVI.
Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
The audio jack would only work with mono plug for audio in, to RGB.
Dec 08, 2009 | LG Televison & Video
No PC Signal on my LG 37" LCD TV?
ON TV MANUAL SETUP PC INPUT ON
CHECK YOU PC ADJUST TO 60HZ....
May 03, 2009 | LG 37LP1D 37 in. LCD Television
I can not get TV to pick signal from PC
I had a problem where my VO22L was giving me a "No RGB Signal" "The Power Will Be Turned Off" message when I had it in RGB mode (with VGA input from my PC). Anytime I left my PC on and turned off the power of this unit, I got this message. I just got off the phone with a very friendly and patient Tech Support woman at Vizio, who talked to several different techs who all came up with things that didn't help. Finally, while we were talking, she came up with the idea of going into the settings menu and doing a "System Reset" to see what happens. What do you know, it worked!
To anyone else having this problem, try this. With the PC and TV on, in RGB mode, go into the menu screen with the remote. The far right tab is "Setup". Use the arrow keys to go down to the "System Reset" option. When prompted "are you sure" select "Yes". I powered the monitor off and on, and the problem is gone. Now if it happens again, I know what to do.
Apr 08, 2009 | Vizio VO22L 22 in. LCD TV
LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
May 20, 2008 | Televison & Video
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
435 people viewed this question
Computer Repairing
Computer Repairing
