Question about GE JVM1653 Microwave Oven
Microwave shutting off in seconds
My microwave just quit after three seconds won't work makes a funny noise then turns off can I fix it myself??
  • wmurray8 Aug 01, 2008
    After 3 or 4 seconds the microware (JVM1653) shuts off and states press clock. I go through the setup and it is the same thingagain. Occassionaly it will operate properly. (intermittant problem)
  • pmb72 Sep 22, 2008
    My microwave shuts down completely after a while. Then, later on, it comes back on and asks for me to input the time on the clock. As if it had been disconnected from power. One solution suggested only covered models manufactured prior to 2000. Mine was manufactured in 2005.
  • GE Master
  • 9,098 Answers
Sadly, we hear of this over and over.
This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
  • William Miller
    William Miller Apr 10, 2008
    I'm not one for the "shotgun" approach to repair.
    Please see my very detailed suggestion about the extremely common magnetron failures.
  • 579 Answers
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Feb 23, 2008
Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
Nov 09, 2009 | Whirlpool MH7135XE Microwave Oven
I have a GE Microwave Model JVM1540LM2CS. It started making funny noises like a fan or gear grinding and then it quit working altogether. I have checked the circuit breakers in the house and have...
sounds like the mag fan went out and blew the internal fuse they are ceramic fuses 15 or 20 amp available at hardware stores ,if this blows again it could be the mag overheated,but the thermal breaker should have shut it off before this,thenit can also be your h.v. diode or capacitor shorted
Oct 10, 2009 | Microwave Ovens
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Funny Noise coming from my microwave
Some of the soup got into the fan. You can continue to use it and hope the noise goes away on its own or you can have a techie clean it.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1533WD turntable sometimes works, mostly doesn't
The part with the three rollers that holds your turntable needs to be replaced if you want it to turn. That plastic and those rollers get cooked over time like everything else. The microwave is designed to basically cook with the moisture in anything placed inside the microwave. Those rollers have probably become warped enough so they don't roll properly when heated and that is why they do work somewhat after a night of nonuse. You may be able to find one at a local repair shop for almost nothing. Those parts are pretty generic. Even at a garage sale or flea market. Other than buying from a local dealer you can go on the internet at www.mwoparts.com and get any part for the microwave. Good luck and God bless you.
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
GE JVM1653 Microwave Oven Logo
212 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
