If Dryer does not tumble , check the following:
It won't tumble
If your dryer doesn't tumble, check these:
BeltMotorDoor switch
Belt
Dryers
have a drive belt that turns the clothes drum. If the belt breaks, the
drum stops rotating. Then you need to replace the belt, and often the
idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
- Remove the belt.
- Check for obstructions in the blower fan housing.
- Manually rotate the shaft of the motor.
If
the motor is very stiff, or impossible to rotate manually, and the
blower fan housing is clear, you need to replace the motor.
If
the motor rotates freely, run the motor momentarily with the belt
removed and the blower in place. If the motor runs fine with the belt
removed, there may be a problem with the idler pulley or the clothes
drum. Try to rotate the drum by hand. If it is very difficult to move,
correct any problem with the rollers or pulley, and then reassemble the
dryer and try it again.
If the motor hums but doesn't rotate on
its own even with the belt removed--yet you can turn it freely by
hand--you usually need to replace the motor or the motor start
capacitor.
Door switch
Your
dryer can't operate at all if the door switch is defective. It's inside
the dryer main housing near the door frame. Sometimes you need to raise
or open the top or front of the dryer to reach the switch. If it's
defective, you need to replace it."Source Repaiclinic
I stuck my hand in behind the the front axel mount, there I saw and felt an axel mounted ring that was loose. It vibrated when the tumbler was turned. Then I took the dryer to an authorized repair shop to be fixed. Don't know yet what the fix is going to be - perhaps a simple job, perhaps a motor replacement. Depending on cost, I'll either have the dryer repaired or replaced. Other than this loose ring problem, the dryer is like new. No scratches, and only lightly used be us two old retired people. Too bad Frigidaire can not make a better product. The dryer says 'Heavy Duty' on the front! Instead it should say 'Made in the US by Union Labor' .
