Question about Dishwashers
Anti-leak valve blocked
I think that the anti-leak valve on my brandt VM515BE1 has blocked, how can I un-block this?
I just de connected the water inlet to realise the pressure and that fixed the problem.
Posted on Feb 09, 2010
How do i know if freeze plugs blew or not?
If there was no antifreeze , and the water in the block froze and expanded the not only did the freeze plugs blew, but you may have cracked your block. Freeze ports are cast in the engine block when made and the plugs for the holes are usually made of zinc alloy and pressed into the block. When the water does not have the proper mix of antifreeze, it expands and forces out the plugs to prevent block cracking. If it is real cold for extended periods of time it may not be enought room for the water to expand and it cracks the block. water on the ground and sometimes the plug that looks like a over sized bottlecap are evidence. If you attemp to start you car you will permantly damage your engine..
Jan 08, 2018 | Cars & Trucks
Why does my Buick Rendevous, 2005, leak water into both front floorboards?
Is it leaking water or Anti Freeze?
If it's Anti Freeze you can pull down the rug or floor mat to check, you should also smell the Anti Freeze. This means your heater core is leaking & has to be replaced, if it's not leaking bad you can try a sealer called Aluma seal (my spelling could be wrong),looks about the size of a roll of dimes, most auto stores have it.
If it's water, my guess is the AC condensation hose is blocked. Does it leak only when the AC is on? this hose runs outside, usually on the
passenger side behind the front wheel, when the AC is on & condensation builds up, you will see water coming out on the ground, this is normal, but if that hose is pinched or blocked the water could end up running onto your floor. Hope this helps.
Sep 08, 2014 | Cars & Trucks
My BMW 318 ti, 1998, overheated, I completely replace the thermostat, I change the radiator temperature sensor, I replace the plastic parts of the radiator, but rolling the car consumes anti freeze, I...
If the car uses anti-freeze without leaking, it is going out the tailpipe. You either have a bad head gasket or a crack in the head or block.
Jul 08, 2017 | Cars & Trucks
Anti freeze leaking from driver side engine block
You did not mention which engine you have but only three things I can think of that will do that. You need to get underneath and check freeze plugs, head gasket and block itself (for cracks). Leaks aren't that hard to find but you need to look!
Nov 15, 2009 | 1998 Jeep Grand Cherokee
Anti freeze leaking into cylinder causing white smoke
Oh dear !
This is a tell tale sign of....leaking head gasket / warped head.
You'll need to get the compression done on the cylinders and/or have the cooling system pressure tested.
Cheers,
Nov 12, 2009 | 1995 Dodge Dakota
Anti-freeze leak
The freeze plugs on the back of the block could be corroded and leaking.
Oct 16, 2009 | 2004 Jeep Grand Cherokee
How do u un block you tube
control panel,firewall, look under exceptions, you may have to add it if its not in list. you should be able to follow the instructions from here.you wll need to be looged as adim. to make these changes.
Jul 23, 2009 | Dell OptiPlex 360 Desktop Computer
Having small puddles of anti-freeze under the block of my 2005 Chevy Impala but don't think its the hoses due to the locations of the leak(s).
3.4 are know to have this problem. It is the intake gaskets leaking. Will cost about 400 to 700 depending on who does the work. Dont take to dealer unless under warrt....Chevy knows but will not fix
May 27, 2009 | 2005 Chevrolet Impala
Anti freeze leeking
I have seen a couple of these now with headgasket leaks to the outside of the block just as you describe. I solved them both with a stop-leak additive, not something I would normally use, but I really didn't want to pull the heads because the exhaust studs always break on these engines. I would find out for sure where the leak is before proceeding though. If it's a hose or frost plug, you'll have to repair it properly.
May 14, 2009 | 1994 Nissan Quest
1997 VW Jetta, 4 cyl, 2.0
YOU HAVE A WATER LEAK SOMEWHERE, AND NEED TO LOCATE AND FIX IT, IF THE WATER YOU ARE FINDING IS ON THE BLOCK, CHECK THE PIPE CONNECTIONS, THE BLOCK PLUGS AND HEAD GASKET
Mar 15, 2009 | 1997 Volkswagen Jetta
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
