Question about Philips Magnavox REM-350 Remote Control
Have a universal remote need code to program hitachi tv
  • 393 Answers
Check out this site
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
Posted on Feb 09, 2010
Remote control codes hitachi cl-4311ug
Hello
Three digit universal remote codes for Hitachi TV are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
OK
Nov 20, 2011 | Hitachi CLU-4311UG Remote Control
I am looking for the VCR Codes for a Hitachi VCR on your remote. Could you please give me the code to program my VCR?
The One-For-All code list gives:
standalone Hitachi VCR: 0000 0042 0041
Hitachi TV/VCR combination unit: 0000
See the following page for the full code list: http://oneforall-na.com/remote.php?type=URC4220 and look for the codes link near the bottom of the page.
If your device was built within 6 months before the remote was programmed or is newer than the universal remote, the codes may not work. If this remote allows, try scanning through all the codes. However, if it still doesn't work, you need a newer universal remote, a universal remote that can be programmed from a computer or an exact or substitute replacement remote for the device. Search remotes.com for a replacement remote - use the model and not the manufacturer for the best chance of finding the remote.
I hope this helps.
Sep 18, 2010 | One For All URC4220 Remote Control
Need codes for a philips universal 0713 remote control
i lost my mannual to my philips universal remote and i need to program it to my hitachy vcr,sharp tv. and my dvd
Apr 11, 2009 | Philips Magnavox Learning Universal Remote
Hitachi 50sv810 Remote
Hi, sorry I confused things on my first post, I understood now that you need a remote to operate the HR 20 , as TV has his own remote.
If you have original remotes for TV and HR20, you should be able to do the job, and that would be best solution.
If instead you want to use an universal remote, the only way out is using auto programming on universal remote, as HR20 codes are not available.
Auto find or auto programming mode is a feature of all universal remotes, you need to check universal remote manual, and follow the procedure, untill this operates your hr20.
Jan 02, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
I need a 4 digit code to work with rca universal remo
1213, 1122, 1123, 1141, 1321, 1434, 1343,
1342, 1123, 1124, 1143, 1114, 1244, 0018,
0019, 0029, 0038, 0047, 0090, 0135, 0174, 0278
Nov 18, 2008 | RCA RCR460 Remote Control
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Need program codes for an RCA CRK93b2 universal remote to work with hitachi 43dx01b also programming instuctions for that particular remote thanx and hope you can help..
I own a One-for-All universal remote and my booklet says the setup code for a Hitachi TV ( without a built-in VCR or DVD) is 0145. I do not know for sure, if this number will work with your remote, but it is worth a try.
Jul 02, 2008 | RCA Televison & Video
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
Philips Magnavox REM-350 Remote Control Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
