Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
My 320 gb ide hdd is not detected to my computer but it is detected with usd external cables .ibut the problem is the full memory is not shown only 1 partition of 48 GB shown rest of 3 partition detail is 0.0 mb free and 0.0mb total.why plz help me to fixed my problem thanks what can i do to repair it and direct detect to my pc.thanks.
Check the master and slave jumper settings on the back where the IDE cable plugs in
Posted on Feb 08, 2010
The computer will not recognize HDD
Check if the usb cable is properly plug. Try to connect it to other computer and check if it will detect your HDD. If not, maybe the usb cable of your HDD is defective.
May 17, 2011 | Toshiba (PA4148E1HC2) 320 GB USB Hard...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
WESTERN DIGITAL WBDAAR3200ABK-00 EXTERNAL HDD NOT WORKING
Every time windows tells you to format the drive, copy your data to your computer then format it. when windows detect problems on the drive, it will launch ckdsk, well i dont know hoy to fix it, try plugging it in then reboot.
May 02, 2010 | Western Digital Elements powered by WD 320...
My 320 gb ide hdd is not detected to my computer but it is detected with usd external cables .ibut the problem is the full memory is not shown only 1 partition of 48 GB shown rest of 3 partition detail...
old computer can work till 160gb as directly connected with serial cable, but when u connect with usb, then it dont act as serial ATA, the technology change if its a PIII computer then it would not work.
Feb 08, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
External HDD is not detected
check the Hdd on a another usb slots uninstall and reinstall the drivers and also check the usb compatibilty if it is 2.0 or not
Nov 05, 2009 | SimpleTech 320GB SimpleDrive External by...
WD Mybook 320. Detected by computer, files all shown, but cant ac
Download the software Recover My Files , google for it and install the software. U can recover with the instructions in the software. it is very easy. U will get the files..
Sep 16, 2009 | Western Digital Passport WDXML800UE...
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
251 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
