Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Are the drills included only for wood drilling? What are the short drills -included- for?
  • 677 Answers
As long as the drill bits do not have points on them you can drill plastic ect.
The short bits are for working in tight areas.
Posted on Feb 08, 2010
Which drill bit should I prefer to drill a log of wood?
You can use a spade bit, hole saw or forstner bit in order to drill into a piece of log. I was also looking for the best drill bit to be drilled on a piece of wood, then one of my friends recommended me to check Best Forstner Bits to get an idea about making the choice of an appropriate drill bit. You can also do the same, if you are confused of making the right choice!
Apr 16, 2018 | Drills
What is the ideal DRILL PRESS for wood working.
How big is your wood that you want to drill?
Take a look in a hardware / diy supply shop.
Apr 07, 2018 | Drills
I'm having trouble drilling into the wood
sherry what are you trying to drill you will need a drill bit for wood or a hole saw for wood.just depends on what your are doing to the wood.
Jul 17, 2016 | Kreg K4 Pocket Hole Jig - KREG
Want to install on wood beam, what size drill bit needed for included wood screws
Look at the wood screw threads and hold a drill bit against it. Choose a drill bit that is smaller in diameter than the threads on the screw. Works for any size wood screw.
Mar 11, 2016 | Drills
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
When running a 3" screw
You need to drill a pilot hole in order to allow the screw to sink into hard woods. This is done by taking a drill bit slightly smaller the width size of the screw and drilling into the wood in the location of the place you would like the screw to go. Then sink your screw into this hole. You should be able to sink your screw with no problems.
May 16, 2011 | Drills
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
Got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Jul 02, 2009 | Dewalt 18 Volt Compact Drill Kit
When I use the drill there is a burnt smell afterwards...what is causing this?
Drillbits "burn" what you are drilling when there is too much friction. That is caused by a variety of things...including...lack of lubrication for metal work...and usually a dull drill bit in wood.
If you see no smoke comming from the point of impact...it might be your drill motor..check it out when you are using it...it could be dirty and need a good cleaning...or it could be burning out from excessive or improper usage.
Apr 24, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
Top kawasaki Drills Experts
jasbo
jasbo
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
