Question about OfficeMax 0M96431 Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Posted on Oct 02, 2010
My office max OM01287 Shredder has no power to it is there a rest button it worked just fine the last time I used it and now there's no power?
Double check the safety that stops the shredder when it is full sometimes that switch gets jammed with cut paper. Also make sure the top of the shredder is level and properly seated back on the base unit. The shredder feed area may also need to be cleared there may be a staple or just paper jammed into this area as well, make sure the unit is unplugged before trying to inspect and clear and part of the shredder
Jan 16, 2013 | Office Equipment & Supplies
I have a shredder from Staples and need to know if the bin full indicator can be bypassed.
A shredder at our office had the same problem. Take out the bin & turn the shredder upside down. There is a sensor on the bottom that looks like two led lights. If it is covered with paper dust, the shredder will think the bin is full. It might work if you simply wipe it off.
The sensor can be hard to find if it is really dusty, so just wipe off the entire pottom really well.
Feb 09, 2010 | Office Depot Ativa DQ60M Shredder
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
Full bin light is always on!
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Jun 04, 2009 | Fellowes Manufacturing Powershred C-480C...
Shredder stopped working
Make sure the bin is not full.
Make sure the bin is fully pushed in.
A shredder will not work if any of the safetys are not properly engaged and for good reasons.
May 27, 2009 | Office Depot Ativa CX10W Shredder
The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Mar 26, 2009 | Fellowes Office Equipment & Supplies
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
OfficeMax 0M96431 Shredder Logo
1,444 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Steve
ka4iup
ka4iup
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
