Question about HP Compaq Presario S5100NX (DM172A#ABA) PC Desktop
Broken hp s5111uk
Just bought a HP S5111uk pc, won't open any discs, fatal errors, won't install printers, is this totally broken?
    Sniper:
  • 79 Answers
The cd/dvd might have gone bad
try uninstalling and reinstalling the dvd drive frm device manager..... go to device manager and then right click on the dvd drive and click on uninstall and tehn restart the comp
Posted on Feb 09, 2010
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Get 'fatal error' during HP C4599 install
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and at what % you get the error is it at 18 % 32 % 56% 94% or 96 % if you get the error at 96% followthe step mentioned below or else please tell us the % at which you get the error
Sep 10, 2009 | Office Equipment & Supplies
I get fatal errors MSI.aio.scan when installing HP
try uninstalling ie8 if you have it installed hp software does not like ie8
Jun 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
Error 2753 HP3050
If it is related to the infamous Fatal Error, MSI.dot4msi, code 2753 of HP installations, then it is not a compatibility issue, but an installation problem.
The HP un-install does not clean its previous installations well, causing some of the dll-s to be locked by Windows, thus disabling install of the new software.
What you need to do is manually delete any trace for HP previous installs from your PC.
Search for HPz*.*, HPw*.*, HPq*.* files, and delete them. Those files that you cannot delete - rename them and delete in safe mode.
Also, search the registry for any HPAIO entries - delete all of them.
Then, reset your PC, and install the new software.
It worked for me (and this is the only thing that worked...)
Good luck
Jun 09, 2009 | HP LaserJet 3055 All-In-One Printer
Dear Esperts, I want to install HP C7280 on my XP Pro. The pop up message appeared as follow: "Fatal error during installation Invalid Drive: E: Fatal Error MSI.netdevicemanager01 " Any suggestion to solve...
Sounds like a problem with the installation disk.
Try clicking on this link the download the Full feature software and drivers package
Allow it to install. If it works your done, if not the disc isn't the problem. If that is the case respond back here with any error messages that show up and I will take a little deaper look into the problem
Hope this helps Fixya,
Chris
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3204785&lang=en
May 03, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C6183 All-in-One installation Fatal
Hi jadeja_mp
From a run box (click Start > type run in start search) type the following command:
msiexec /unregister
Press enter then open a new run box and type:
msiexec /register
Press enter
Try installing the printer software again. Does this help?
May 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet F2280 - It scans but doesn't print. Shows fatal error.
Hi Amnasaeed
Follow this document, even I was facing the same problem and this document has taken care of my issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01430567&cc=us&lc=en&dlc=en&product=3390947
follow the document and get back to me if the problem is still not fixed.
Thanks & Regards
Santhosh
Jan 27, 2009 | HP DeskJet F380 All-In-One Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Fatal error installation of ProL7590
There are alot of fatal error messages. You need to provide the exact fatal error message.
Here are the basic troubleshooting for that type of error :
1. Turn off your firewall, anti-virus and spyware and then install it
if it will not work
2. Download the software for your printer in the website www.hp.com/support make sure that you are going to download and install the full feature of the software
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Compaq Presario S5100NX (DM172A#ABA) PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
