Warmflow Oil Boiler Help Needed
Hi All
I hope someone can help me.
I have a warmflow utility 70 oil boiler and a riello rdb pump.
The boiler cuts out every so often and I have to reset it. The first time I reset it it cuts out again after 5 secs or so but the 2nd time it works ok for a couple of hours.
I have bled the pump and also cleaned the photo cell.
Does anyone have any idea what the problem could be please?
Any help would be appreciated.
Many Thanks
Dave
  • 1,420 Answers
Try changing the oil pump screen. If it still fails, replace the primary control.
Posted on Feb 09, 2010
I've a warmflow boiler, it will heat radiators for about an hour then cut off. If I leave it a couple of hours then turn it on again it will work.
There must be a HIGH temp cut off that is shutting off too early then cooling and coming back on . Sorry mean overheat cut off .
Sep 25, 2017 | Heating & Cooling
What does the white smoke coming out of the top of the flu on my oil boiler mean
White smoke means steam and that would be caused by a leak in the heat exchanger coil of water in the fuel.
May 02, 2015 | Biasi B-6 Oil Boiler w/ Riello Burner -...
Constantly runs
Zone valve stuck, or switch on zone valve faulty.
Jan 05, 2014 | Biasi B-6 Oil Boiler w/ Riello Burner -...
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
Wiring Diagrams
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
I have riello oil burner put oil into a empty tank tried to bleed it now it won't fire up can you help
is the filter clean u might of picked up sludge in bottom tank also blow out the supply lines and re fitt try again
Sep 23, 2013 | Honeywell Biasi B10-3 Boiler ,riello...
Riello oil burner runs for 2 seconds and then stops ??
1. Take off the red cover which is held on by a screw.
2. Use an allan key to loosen the screw facing you.
3. Turn on boiler. The boiler will draw the oil through and bubbles of air will escape through the screw you have loosened.
4. When it is just oil coming through the cracks around the screw, re-tighten the screw and turn on again.
Feb 15, 2012 | Heating & Cooling
Riello oil burner RDB Hi everybody i have a Riello oil burner RDB . I am wondering is there a way to make it more oil efficient?
does it have the air damper installed? You can add a magic heater to the flue and dump heat into your basement.. thats maybe 5 to 10 percent more efficient
Sep 25, 2010 | Heating & Cooling
Oil fired boiler 2 pipe system 150ft to tank
A two stage pump may help, because you are pulling a long distance. However I have found that a little contraption called a "Tiger Loop" is much more effective at making the problem you are having go away.
I have written a tip here on Fixya that you can see by going here
http://www.fixya.com/support/r3571544-oil_burner_problems_can_sometimes_be_fix
This unit will cut the amount of oil that you need to move through only 1 of the pipes down to amount that is actually being burned.
Be sure to use the "supply" pipe to hook to the Tiger Loop.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 07, 2009 | Dehumidifiers
Riello oil burner RDB with red plastic cover at the front wont ignite. I've tried bleeding the valve. The motor seems to make an electrical humming noise for about 12 secs, then the system attempts to...
The motor should spin when the boiler is switched on. One end of the motor spins the fan the other end works the pump. The control box then starts the transformer that starts a spark. The control box then opens up the oil. The boiler should then light if any of the above or the boiler does not light, the boiler will go to lockout.
From what you say the motor is not spinning, thus it could be the motor or more like the pump.
YOU SHOULD NOT PLAY WITHE THE PUMP
If the wrong setting is made it could 1 burn out the back of your boiler 2 go to soot and the boilers in an hour would be filled up and become a fire risk. 3 not start at all if the setting is too low it is a fine line to get it to work and needs the right tools.
regards
oil eng.
Oct 26, 2008 | Heating & Cooling
Heating & Cooling Logo
403 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
