Canon PC850 When trying to copy, the copier makes a loud buzzing sound, and the copied sheet comes out dark with thick lines down the center of the sheet (short way), and then jams. This happened every so often, though now will jam more often than not. Is it the cartridge or something else? Help!
  • MelissaG Mar 13, 2008
    Copy has a black line down the middle? Help!!!
    Thanks,
    Melissa
  • Anonymous Jan 20, 2009
    I took the drum out and the purple roller had toner lines that matched up with the bad line on the copies, and cleaned it with a clean t-shirt; it got better for a copy or 2, than bad again, but only on 2/3 of the copy.... top 1/3 prints beautifully. is there a proper way to clean it? what other implements should be cleaned (brushes, etc) could i have damaged it beyond repair? thanks.
    -jb
    Problem Solver:
  • 6 Answers
Blcak line, if you have a doc feeder, clean the **** glass, if it down the middle, change the toner cartridge unit, or the drum, it jams where it gets hot replace the fusing unit..
Posted on May 17, 2008
  • 86 Answers
Yes try change the print cartridge its probably done its life.
If the problem persists please get back to me
Thank You
Posted on Feb 22, 2008
Why is canon ir 3300 making dark lines on a copies please help
Did U check the drum? How many copies made?Can also be a transfer rolerr,or fixing film in heather
Aug 04, 2014 | Canon Ir 3300 Black & White Copier
Image distort when copying and horizontal lines
Getting caught? Loose paper shred inside feeder?
Mar 28, 2014 | Canon D320 imageCLASS Digital Copier
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
I have a canon pc850 the roller is squeeking.
Wich roller?
If the sound is geting from drum unit, replace drum unit.
If sound is getting from bushings or axis apply small amount of wd40 or similar.
Jun 29, 2010 | Canon Office Equipment & Supplies
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
I want to darken copys on my canon pc850
it seems you used the cartridge upto 3 times usage. you may need to change the drum.
Feb 17, 2009 | Office Equipment & Supplies
Canon PC850
1.replace OPC drum
2.clean your Canon...
Jan 20, 2009 | Office Equipment & Supplies
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
Black Line Down Center of Page
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Feb 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Open Questions:
244 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
