Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Display flickering black and white and does not show until I unplug it and plug it back in.
  • ksbrowne Feb 08, 2010
    Hi... I did a quick check to re-install drivers but I am using a mac and could only find exe files for driver updates and fixes. I did find one web site that talked about this problem with Mac. I have had this monitor for almost 3 years, it should still be under warrenty if I could find the documentation.
    CCan you steer me where to find a replacement mac driver?
    All I can find on these sites are PC systems, not Mac OS, unless I am overlooking something.
    K
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.The first thing you should try is to reinstall its drivers, if it still wont work then it seems the issue is with the power board or the main board thats going bad and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where, the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all he inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    Please check out these links for driver update:
    Samsung Sync Master 204B Driver
    Samsung SyncMaster 204B Driver-2
    Samsung SyncMaster 204B Driver-3
    Thanks
    Rylee
  • Rylee Smith
    If you are unable to download the software from the links that I gave then as I said you try to search for it as I think the issue should be resolved once you get the drivers. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My hp CPTOH-0602 was flickering and then stopped and now the screen is dark with a big black area in the top left corner
it was a screen back light failure, the lamp get busted in the upper portion of the panel display. to access this part you will need to remove the back cover using a philip screw driver. the back light is covered with metal shielding.to replaced the back light, be careful in disassembling the cover not to damaged the lcd screen panel.
Nov 26, 2012 | Televison & Video
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
How can i repair a optoma 706 lcd displaying white and black vertical lines?
FAULT: If lines are flickering with black and white and there is no data in line its mean the DLP unit is faulty.
SOLUTION: the only solution is this that you replace the DLP unit the DLP unit is electroniccomponent and not a repairable (as show in picture) good_help_19.jpg
Jan 24, 2011 | Office Equipment & Supplies
Blinking black in play mode!!!! PLEASEEEEE HELLLPP
If this is the same as my Nikon this is the overexposed highlight display option.
This shows areas of the photograph that are overexposed slightly.
On my Nikon I use the up and down arrows on the back to cycle the LCD display options.
Stop when you get a display that does not flash.
Jul 06, 2009 | Nikon D40 Digital Camera
Multiple screen coming up in black and white also flickering on and off
I have a logitech quickcam E3500
I have 4 black & white images
I tried downloading older and newer versions of the software, no joy.
From the logitech site, I found this fix:
Go to Start>Run, type "dxdiag", wait for the application to show, then go to the "Display" tab and disable Direct3D acceleration or Directdraw acceleration. Exit. That's all.
I tried it and it works a treat.
May 16, 2008 | Logitech QuickCam Pro 5000 Webcam
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
