Question about Canon Office Equipment & Supplies
I have a cannon Ip6600D and all of a sudden it stopped printing all the ink tanks are full and a occasion some things will print but most of the time the sheets are blank
    Problem Solver:
  • 10 Answers
Does your printer tell you that all the ink tanks are full? if it says that one is empty you may get intermittent printing, but it sounds like there's a clog in the print head itself.
Try doing a deep clean though your software. it will use the ink, but should flush anything out. Also make sure that you are using this printer at least once a week (this is the biggest reason for clogs, other then using a cartridge that was refilled using generic ink).
Posted on Feb 08, 2010
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My IP6600d has suddenly refused to print, saying 'the following ink tank cannot be recognised'. It says its the yllow cartridge, which is half used and a genuine canon item. I have tried taking it out and...
Have you checked the quality of the chip on the yellow ink tank? If scratched, the printer will not be able to read the ink tank information and will stop. I had to replace an ink tank in the past with another one with a new chip due to the first one was defective. If you have a spare yellow tank with chip, you may want to replace the old one so you can continue on.
Dec 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon i470D Waste Ink Tank is Completely Full. How Do I Clean It?
There is a cleaning solution sold on E-bay for Cannon i470D print heads.
Or you can try a little ammonia. I used a cap full of ammonia in each side of the print head where the ink tanks go.
Put the print head in a can and let it set in the ammonia for 5-15 minutes then blot dry with paper towels and let stand until dry.
Then run the maint routines for the print head found under properties/maintance.
Dec 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Paper ejected
try by reloading the software for the printer
May 19, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Photos print blue
you have to clean the print heads.
Feb 27, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
old marine
old marine
